Boost guage off-zero
Results 1 to 8 of 8
This is a discussion on Boost guage off-zero within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have a VDO mechanical boost guage that I used on an old AWD Talon I used to have. I ...
    Registered User REX2ning's Avatar
    Feb 2006
    Kaiserslautern, Germany
    I have a VDO mechanical boost guage that I used on an old AWD Talon I used to have. I was about to install it on my 02' WRX when I noticed that the needle on the guage is already sitting on 1 lb of boost, not on zero. Is my guage broke or will it fix itself once it gets a reading? Also, am I retarded for installing a mechanical boost guage?
    Thanks,
    Tim
    Jun 2005
    east northport ny
    this is a problem for alot of mechanical gauges, if you look at an autometer gauge, the zero is a large area of the gauge, the needle is never 100% where it needs to be, sometimes even out of the box, try giving it a little vacuum or boost with your lung charger and see if it corrects at all.
    an no you are not retarded for installing a mechanical gauge, better than no gauge at all, and if you choose one day get something with a stepping motor.
    oops
    Registered User orvtech's Avatar
    Nov 2005
    Miami
    Really ?
    Quote Originally Posted by longislandwrx
    Really ?
    - n00b question on the way -
    whats the benefit of a boots gauge ?
    do you recommend one ?
    Jun 2005
    east northport ny
    Quote Originally Posted by orvtech
    Really ?
    yeah look how big the zero zone is
    on a stock car not many aside from seeing how climate/altitude is affecting how much boost you are running, also you could tell if you were severly underboosted because of a part failure or boost leak etc.
    on a modified car boost control is very important and a quality boost gauge can alert you to the fact that you are not hitting targed boost. if you are overboosting/boost creep and other dangerous conditions.
    im sure others will post more
    oops
    Nov 2005
    Miami
    so... for my stock wrx it will only let me know if it is underboosting but it has no other usefull (besides looking cool) use ?
    Jun 2005
    east northport ny
    pretty much
    i guess it would also let you know if the wastegate failed and you could theretically hit high boost levels. which would also be good to know, or any other failure factors which would cause boost to fluctuate. it may also interest to see the peak boost you are hitting in various gears
    oops
    Feb 2006
    Good advice on the boost gauge as a nessecity. Before throwing on any engine mod its always safest/best to see how the motor is responding as far as boost levels go, hence the gauge.
    Ill give correcting the gauge manually a shot. I never would have thought that I could do it myself like that.
    Thanks,
    Tim
    Jun 2005
    east northport ny
    well you wopuldnt really be correcting it, but from sitting the nidle may just be sticking/and by giving it some pressure/vacuum you could free it up.
    oops
