Window leak
Results 1 to 15 of 15
This is a discussion on Window leak within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; When i drive around 45 mph and above, i hear air seeping through the driver window, anyone ever hear that ...
    Feb 2006
    Thousand Oaks
    Window leak
    When i drive around 45 mph and above, i hear air seeping through the driver window, anyone ever hear that too?
    04 wrx cutom 2 tone leather.
    Registered User Janus's Avatar
    Nov 2004
    Massachusetts
    yup just roll the window down and back up and its fixed.. everytime you open the door anyway
    luxury is 1.00 BAR+ of boost and the inability for your passenger to touch the dashboard
    Feb 2006
    Thousand Oaks
    i do that, but it still leaks. i think the weather stripping needs to be reaplaced
    Jul 2004
    State College, PA
    i can hear the wind also, im guessing its the weather stripping
    Registered User silvewrx's Avatar
    Aug 2005
    Connecticut
    mine does it as well, right above where the mirror meets the weatherstripping. I also find it stops when you put the window down and back up, but does anyone have a more permanent solution to this problem? It appears the triangular piece that seals against the stripping seems to crease the stripping, allowing an air leak when pressure is appklied. Has anyone else noticed a whistling noice with the sunroof tilted. It is apparent whether i have the air deflector installed or not.
    New England F4
    If you're not shifting, you're just riding.
    I totalled my WRX
    Apr 2004
    Southeastern PA
    It is a bad window design imo. This is the third car I had with frameless doors. Doors that I have had with window frames attached to the door did not leak
    Mods & Pics
    Registered User MasiveMunkey's Avatar
    Jan 2003
    Downey, CA
    Wow I have that same problem, it goes away when I roll down the window and roll it up also. I wish there was a perminant fix though even though it really doesn't bother me too much.
    -Eric
    Originally posted by lanevoell
    stand up for yourself, painter!
    Wesome +1
    Registered User silver03's Avatar
    Jul 2003
    10000 Lakes
    window leak
    Same problem on my 03. I had the dealer adjust the window, that helped. I still need to roll down after door is closed and roll back up again for a complete seal.
    Feb 2006
    Thousand Oaks
    how much was it to have the dealer to fix it?
    Jul 2003
    10000 Lakes
    window leak
    mine was covered under warranty.
    Registered User cavallino333's Avatar
    Feb 2005
    Campbell CA
    If you think wind noise is bad in a WRX try driving a Ford Taurus.
    FORZA FERRARI
    BLOBEYE SYNDICATE (retired) #13
    Quote Originally Posted by Integra96 View Post
    One day I hope to buy a car that is lubricated exclusively by pure manatee oil.
    Registered User TDQuiksilver's Avatar
    Dec 2004
    Bay Area, CA
    Yep, get it here too.. just something we've got to live with. Roll down roll up. Fixed
    Administrator BlazinWRX's Avatar
    Apr 2001
    Irvine, CA 92620
    My driver side window is actaully misaligned with the frame of the car. Currently it pops out about 1" so it gets really noisy... I'll most likely take it to the dealership when I get my 60,000 mile tune up
    Tim
    Admin
    Oct 2005
    Late Devonian
    The dealer adjusted mine under warrenty and it went away.
    Jun 2005
    Massachusetts
    Yes
    BUGEYE
    South shore MASS
    20 percent...I'm too good to be seen
