GReddy Informeter
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
This is a discussion on GReddy Informeter within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Anyone here running this in his/her WRX? I was thinking about getting one instead of getting all of the gauges. ...
    Feb 2006
    GReddy Informeter
    Anyone here running this in his/her WRX? I was thinking about getting one instead of getting all of the gauges. What do you guys think of it?
    http://www.optionimports.com/grinin.html
    Registered User LeeC's Avatar
    Oct 2005
    Baltimore MD
    I'm going to order one from RallySportDirect soon, it seems like a really good deal, I want to see where other people have mounted their's before i buy it though.
    Pics anyone?
    94 Anthracite 6spd Supra - 9.87@147
    LS2 RX7-2014 Tundra DC-GD Race Car In Progress
    Registered User WRXNavigation's Avatar
    Aug 2005
    Central NY
    Pics would be awesome. I am also considering this. I did a quick search on google and found if at many places. All were less than 360. Some were even almost $100 less. So make sure you look around for a good deal because $360 is the Greddy MSRP and very few things sell at MSRP.
    Oct 2005
    Baltimore MD
    I just ordered mine from a local shop, it will be here tomorow, I payed 300 shipped next day and the cheapest I found it online was $275 so I just rather of bought it at the shop. Anyway, tomorow once I hook it up I will post up some pics.
    Feb 2006
    Quote Originally Posted by LeeC
    Nice! After you hook it up an everything, can you give a list of what it tells? Hopefully it will show EVERYTHING, PSI, EGT, AFR? stuff like that. Im assuming that the OBDII in the 02 will be the same as the OBDII in the 06?
    Sorry for my lack of apostrophes, there is something wrong with my keyboard and everytime I hit that key, It pops up my find thingy at the bottom. I think I need to restart.
    Aug 2005
    Central NY
    LeeC, definately please post back here once it is installed. I am really interested in this device.
    Registered User cavallino333's Avatar
    Feb 2005
    Campbell CA
    Quote Originally Posted by WRXNavigation
    +3
    FORZA FERRARI
    BLOBEYE SYNDICATE (retired) #13
    Quote Originally Posted by Integra96 View Post
    One day I hope to buy a car that is lubricated exclusively by pure manatee oil.
    Registered User UR MOTHA's Avatar
    Dec 2001
    Fountain Valley, CA
    Sounds pretty awesome, I found this info on projectnissan.com:
    Read up to 25 pieces of information
    Communicate with the factory ECU toreadupto25 Channels. Like: Speedometer, RPM, Water Temp, Ignition Timing, Injector Rate, Intake Air Temp., Fuel Temp., Air Flow Voltage, Intake Manifold Press., O2 Sensor Voltage, A/F, Battery Voltage, Throttle Position, WGV, ATF Temp., EGR Temp., Gear Position, 4WD ratio, Exhaust Temp.
    If this thing does boost too, I'm sold.
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    I'm curious about this unit also. I'm trying to picture a wire from the OBDII port and a power cord going to this unit. My dash is getting messy already with sirius and V1 stacked on it. Might have to go hardwire.
    I did notice on one website that it had a caution that it "may not monitor all parameters listed", so I wonder how vehicle specific it's software is.
    Please post pics and thoughts when you get it installed. Did you also get a mounting kit with it? The only one I found was in the UK at it was basically an ipod holder with a suction cup.
    This was the cheapest site I could find it, so you could at least us it somewhere else for a price match reference. 275 bucks.
    http://www.intensepower.com/grininfcosh.html
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Dec 2001
    Fountain Valley, CA
    Quote Originally Posted by YBNormal07
    Right, I would imagine it depends on the car to some degree. And obviously something like the "4WD ratio" would only be available on suitably equipped vehicles. Still, if it does even half of what it claims it would be extremely useful.
    Oct 2005
    Baltimore MD
    Quote Originally Posted by UR MOTHA
    Quote Originally Posted by RallySportDirect
    It can display up to 25 items. but not all cars will have all items. Bascily if your obd2 port has access to info about your map sensor or your o2 sensor this should be able to read and display what its doing in real time.
    A common question is does it read boost? well it does, but what it is reading your map sensor to get that reading. so if you use a fcd of any sort, mechicnal or electric there will be a point where the reading this gives you is off.
    -Jason
    Rallysport Direct
    Thats from the thread where RSD announces they have it...
    Can't wait to get it tomorow
    Dec 2001
    Fountain Valley, CA
    sweet. I might just have to order one this week
    Oct 2005
    Baltimore MD
    Cavallino, this is a list copied from RSD's post in the vendor announcment forum, this thing is great =D I have to photobucket my pics then ill post some up, Sorry for the bad quatlity they were pretty quick and i had my friend drive to take some while in motion.
    Anyway... it displays Speedometer, RPM, Water Temp, Ignition Timing, Injector Rate, Intake Air Temp, Fuel Temp, Air Flow Voltage, Intake Manifold Press, 02 Sensor Voltage, A/F, Battery Voltage, Throttle Position, WGV, ATF Temp, EGR Temp, Gear Position, 4WD Ratio, Exhaust Temp.
    But for some reason i couldn't get the gear postion to work (no biggie)
    I don't have the 02 sensor ones working either but im guessing thats due to my exhaust
    Oct 2005
    Baltimore MD
    Errrr my post didnt show up?
    *test post*
    EDIT: ok, time is off on here and posts are like going back spaces... weird
    Oct 2005
    Baltimore MD
    (ok so its really like 1015 here (the time on the site is weird so this post will be like Mid-Thread
    Very dirty hood =/
    Black Faceplate on
    Only complaint really is there is no harness or stand (which would help alot since there is no great place to mount it)
