Triple gauge clock pod for an 06
Results 1 to 4 of 4
This is a discussion on Triple gauge clock pod for an 06 within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I was wondering if anyone can recommend a clock pod for three 52mm gauges for my 06 wrx. I am ...
    Oct 2005
    long island
    I was wondering if anyone can recommend a clock pod for three 52mm gauges for my 06 wrx. I am going with boost egt and oil pressure. I have looked around and have come across many different clock pods ( expensive and cheap). I was also wondering would happen to the airbag on/off light next to the clock. I hear if you disconnect it the airbag light on the dash will illuminate.
    Registered User hellbilly1342's Avatar
    Dec 2005
    Quote Originally Posted by 06-wrx
    the pass airbag on/off light must be new for '06. but yes, i am pretty sure if you disconnect anything that pertains to the airbag system the warning light will illuminate.
    and for the gauge pod, get one that has the angled face plate. easier to view from driver seat.
    So Cal F4 member #19
    Oct 2005
    long island
    I just have to figure out what to do about the pass airbag on/off light. I have heard that if it is disconnected the dash will illuminate. Maybe I would be able to disconnect the whole unit with the pass airbag light and just let it sit down it the whole in the dash. Its going to be covered by the pod anyway. Where can I get one with an angled face? If I get some free time later I am going to check out the airbag on/off light
    Registered User Dr_Evil's Avatar
    Oct 2005
    Calgary, Alberta, Canada
    If you just took the little tiny circuit board that it plugs into out and left it in there, I'm sure it would fit under a gauge pod. I've had mine all apart and the actual electronics in there are pretty tiny.
    Black 2006 WRX Sedan
    Snorkus-deleted with K&N drop-in
    Defi-Link Boost, EGT, Oil Temp - Gruppe-S CF dash pod
    TurboXS Turbo-back
    That's it so far!
