That looks awesome, very clean!![]()
This is a discussion on My V1 Radar Detector Install within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hey all. Just wanted to share some pics of my V1 install. I think it is pretty clean. I decided ...
Hey all. Just wanted to share some pics of my V1 install. I think it is pretty clean. I decided not to go with mounting it up by the rear view mirror. Since my WRX is an 05 it has those sun blocker dots and I didn't want to decrease the effectiveness of the detector. I also wanted it lower so that the detector can see out the rear window. Basically I went with mounting it where the manual says is best.
COBBS!.....We got COBBS everywhere meng! COBBS, COBBS, COBBS!
Blobeye Syndicate #2
RYB - 01
"RALLY ON"
Originally Posted by StreetSlider
Thats nice. I just got a ticket for mine so im trying to figure out a way to hide mine..Looks good man.
My money pit
wow. nice. thanks for sharing.
it looks so much cleaner. After i get off work I have to go do that.
outa Mai w@y...
Very clean..... any tips on the install? Im going to hardwire my x50 soon.
...If you ever need anything please don't hesitate to ask someone else first.
Blobeye Syndicate numero uno.
I wired my V1 to the wiring supplying the clock. I used some snap on wire splices. The clock itself has all four wires labeled (Battery +, Illumination, Ground, and Accessory) so there was no guess work there. All I had to do was peel back some of the electrical tape, make my connections, and re-tape it all up for a clean look. I drilled a hole just large enough to pass the RJ-11 connector for the detector trough it and then set a rubber gromet to provide a clean look as well as prevent the connector from falling back into the dash.Originally Posted by DJSHADOW7
There is plenty of room in the dash around the clock pod to hde wires and such so no problems there. The rubber grommet I used is available at most hardware stores in the electrical sections. Hope this helps. Let me know if there are any specific questions.
This is how you blend the V1 into a Subaru !
And should see my Blinder Installtion !!
wtf... details.
Snale Power: -BriTon
06 STi=dead
RSTi Swap FTW
Hawk-Eye Allience #013
and in action:
This kit is made by www.a-bond.com
One of the coolest things I've ever seen. For some reason I have the Night Rider theme stuck in my head now.
Originally Posted by subaru4wd
That is a very slick install of the remote face. However, I am curious where the main receiver is mounted? Can you fill me in. I was going to do a slick stealth install but wasn't sure how you can hide a device that relies on open line of sight for best performance. (I am not knocking the install, I think it is awesome, I am just curious)
I guess it used remote sensors. but +1 on the question ^^^
06 STi=dead
RSTi Swap FTW
We definitely need a lot more info....I'm thinking about calling Jack Bauer to get the info outta ya if you don't start talking![]()
2004 WRB WRX
Interior: Momo shifter knob, door sills, red bulbs on HVAC, fog light, keyring, clock
Exterior: OEM spoiler, sideskirts, red brake calipers (G2 set), cleared headlights (all white), Blue "i" emblem
Tint: 30% front/side 20% back
Audio: Kenwood MPV 7019 head unit w/ mp3 adapter
Power: OEM SPT catback exhaust system, K&N air filter
Each Blinder tranciever is installed with two electric motors with an amplitude of about 25 mm, and they move the blindres up/down behind the bumper/fender.
The hub (interface box) is installed inside the car.
The leds (red and green) you see right side to the V1 dispaly are the led of the blinder and the status led of the system (green for stealth and red for hidden).
This installation has been tested with a laser gun and the coverarge is excellent.
Inside the car you have a toggle switch to activate the system when needed.
I added a master switch using an original fog lights subaru switch.
Here is what you have inside the car.
and the master switch for the system and the Blinder.
can you explain what you mean by blinder? So is it a radar detector, or what?
