Results 1 to 11 of 11
This is a discussion on STI Roll bar completed within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I just did this 2 weeks ago. STI Roll bar with all interior intact with no cuts except carpet. Material ...
    Registered User cagedruss's Avatar
    Feb 2006
    I just did this 2 weeks ago. STI Roll bar with all interior intact with no cuts except carpet. Material meets SCCA Specs 1.5"x.125" DOM. Bar is custom bent for this car and and has diagonal and horizontal bar. Driver is a rather big man and needed extra room. Sometime next year owner may make this car into a dedicated racer and we will finish of the bar to a cage.
    Attached Thumbnails Attached Thumbnails 100_0818.jpg   100_0826.jpg   100_0824.jpg   100_0821.jpg
    Feb 2006
    Opps, sorry. Posted wrong picture, my bad!
    Registered User TOOFAST88's Avatar
    Oct 2005
    Champaign/Buffalo Grove, IL
    Nice
    Looks like some solid work
    COBBS!.....We got COBBS everywhere meng! COBBS, COBBS, COBBS!
    Blobeye Syndicate #2
    RYB - 01
    "RALLY ON"
    Quote Originally Posted by StreetSlider
    Hellen Keller's favorite color is Blobeye Syndicate.
    Registered User speeddr2000's Avatar
    Mar 2005
    jacksonville
    clean weld's u tig that ?
    Feb 2006
    Quote Originally Posted by speeddr2000
    No, just wire fed, did not want to add extra expense to tig. It is about an additional 30% more.
    Boba Fett BrianH's Avatar
    Oct 2003
    Kicking Babies
    good work!
    Registered User SHO_Guy's Avatar
    Sep 2004
    Iowa
    Quote Originally Posted by BrianH
    good work!
    +10 Indeed. Nice, clean and to the point (no pun intended) .
    Registered User awd4life's Avatar
    May 2005
    the LC nuevo mexico
    looks tough, i love the tiger stripes on clean DOM steel. did you bolt the tubing support plates into the chasis or stitch weld/box them in?
    Feb 2006
    It is completely welded in. I really can't mount the roll bar to the optimum location if it is bolted in. Bolt ins have to allow room for the opposing plates. If need be, owner could sawzall the bar out and do a little grinding and the car would be back to original configuation. Since I did not cut any interior except carpet, it would be an easy job. At this time owner has no intention of coverting this platform into a stock street ride. Plans are for full race car in a year or so.
    H4N
    H4N is offline
    Registered User H4N's Avatar
    Nov 2004
    Worcester, Mass
    nice job man, looks badass
    ________________
    ¦¦ New England F4 ¦¦
    ¦¦ i R TeH GoD~!! ¦¦
    ¦¦ http://www.autobonproductions.com ¦¦
    May 2005
    the LC nuevo mexico
    Quote Originally Posted by cagedruss
    a few more ?'s if you don't mind. did you weld the tubing to the sheet metal, it looks like a pretty hot weld in the pic of the rear seat. if so how did you keep from burning through the thin sheet. and what did you use to prep the surface, on the cage i have done i hated having to deal w/ the sound deadening gunk. thanks.
