Results 1 to 5 of 5
This is a discussion on Boost Gauge Install ? How to ? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hi all, Just Received my Pro Sport Performance Boost Gauge today.. I understand the easy part of the vacum line ...
    Registered User wrxhunter's Avatar
    Dec 2004
    Richmond hill, Ontario
    Hi all,
    I understand the easy part of the vacum line to the boost gauge but not sure what wires i should be spicling to connect the other 3 wires..
    Power, Ground , ignition wires .... not sure where to start ?? from behind the dash ? clock ??
    anyone know of a good HOW TO thats been made ... did a search couldt find anything good
    THanks all
    2003 ASPEN WHITE WRX
    Stage 2 !!!!
    Registered User TheFugitiveMind's Avatar
    Jul 2005
    Ventura County,CA
    on my 05, i used the Factory Boost Gauge Harness located on the Radio Harness.
    i used spade connectors to tap into the Ground and 12v. i believe the neg. controls the dimmer.
    i hear the clock is a good way to do it to.
    Registered User psychobooe's Avatar
    Mar 2004
    USAF
    Check out www.scoobymods.com
    I'm pretty sure that they have a good write up of how to install a boost gauge.
    Try not, do or do not. There is no try. - Yoda
    Mods
    Registered User mike05STi's Avatar
    Jan 2006
    Nashville, TN
    Ok, so I'm going to assume that the STis with the factory boost gauge mounted on the column is not good enough? The one ('05 STi) that I'm picking up this Friday has one. I've heard it's too small to read but I have no problem reading or seeing it.
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    -Albert Einstein
    Some people go through their whole lives wondering if they ever made a difference in the world. Marines don't have that problem.
    -Ronald Reagan
    May 2005
    Phillytown, PA
    Quote Originally Posted by mike05STi
    The factory one is fine, as long as you like it/can read it.
