Boost, EGT, Oil Pressure guage help
Results 1 to 8 of 8
This is a discussion on Boost, EGT, Oil Pressure guage help within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I'm gettin ready to place my order and get a Boost, EGT, and Oil pressure guage and it's asking me ...
    Nov 2005
    So Cal.
    I'm gettin ready to place my order and get a Boost, EGT, and Oil pressure guage and it's asking me if I want to purchase a pressure sandwhich adapter with it for an extra $39? Can someone explain to me what this is. Also isnt $119 a bit much for a Autometer A-pillar 3 guage pod. Any other suggestions on where to get a guage pod like that a bit cheaper? Thanks for the help.
    Nick
    http://www.daddysscp.com/dcart4/prod...&cat=13&page=1
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    I think the sandwich adapter lets you take your pressure readings at the drain hole but I'm not positive. I installed my pressure sender in the port under the intercooler and there you only need a thread adapter.
    $119 for a gauge pod seems kinda high. Try http://www.egauges.com/vdo_acce.asp?...WRX_Pod&Cart=1
    06 S40 T5 AWD
    Previous: 2004 WRX
    05 CBR600F4i
    Registered User wrxrolla's Avatar
    Ames, Iowa
    The sandwhich adapter goes inbetween the block and your oil filter, thus a sandwhich. I believe it has two outputs so that you can run a oil pressure and oil tempature gauges with a relative easy install. I'd do what 04blkwrx suggests and just get the thread adapter.
    Andrew
    Never quit. Never do the expected. Never follow.
    http://www.cardomain.com/id/wrxrolla
    Registered User C Stoyer's Avatar
    Jan 2004
    Pennsylvania
    I have the sandwhich adapter in my set up and yes it has two ports. I installed Oil Temp and Pressure in mine.
    Registered User osirissirhc's Avatar
    Sep 2006
    Glenwood Springs, Colorado
    where is the location of the threaded hole for an oil pressure sender? pics very much helpfull
    Registered User ryanwrxduksa's Avatar
    Jun 2006
    NW ct
    the best place for oil pressure or temperature is the galley plug under tmic. or just remove the dummy light. if you use the top galley plug you can order from subaru a double threaded plug for the sender. thats my $0.02
    07 white STi in CT
    May 2005
    Phillytown, PA
    Quote Originally Posted by ryanwrxduksa
    That really is the way to do it. Good thread on nasioc.
    Sep 2006
    where is the dummy light i would go over to the subaru dealer and ask them to see their books but showing up in my toyota uniform would be a little weird ..... and im pretty sure that if i just walked in there with my normal clothes on they wouldnt let me see it
