Crossover location?
Results 1 to 12 of 12
This is a discussion on Crossover location? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Who has the best place to put a crossover in a WRX?...
    Jun 2005
    Portland
    Crossover location?
    "sitting in the corner in Rick Roll timeout" chanwahyaoh's Avatar
    Mar 2004
    Detroit
    probably inside the door panel would be the best spot.
    Turtles are nature's suction cups.
    .____
    ||J || R.I.P.
    ||__||
    |/__\|
    Jun 2005
    Portland
    That is what Ive heard, but then people say not to do that due to shield problems.
    Mar 2004
    Detroit
    Quote Originally Posted by BlakeTTS
    i've never heard of that. Then again, mine were mounted under my seats.
    .____
    ||J || R.I.P.
    ||__||
    |/__\|
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    I mounted mine on the door. When you take the door panel off there's an area with foam on the panel... I cut that out and mounted the crossover on the door where the foam would be...
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
    Jun 2005
    Portland
    Did you install them yourself? Cause it seems like its gonna be quite a pain in my a@# to get in there and do it.
    Is in Love With the Admins Here 20WRX04's Avatar
    Nov 2004
    WNY
    I've always mounted ones i've installed behind the kick panels. I'm not sure if there's room behind them on Subarus though.
    The first rule of the Faction is...DO NOT TALK ABOUT THE FACTION.
    NY GIANTS
    Hybrid Faction #19
    Blobeye Syndicate #19
    Mods
    Oct 2002
    Bergen, NJ
    If you can't take your door panel off then maybe someone else should install them for you. Putting them in the door isn't hard at all.
    Putting them in the kick panel area isn't a bad idea either and might actuallt protect them from water better...
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    Jun 2005
    Portland
    well, I meant that the pain in the ass would be to get the wires through the door. Oh well, we shall give it a shot
    Oct 2002
    Bergen, NJ
    That's one reason I like mounting the crossover in the door... you only need to run 1 wire into the door and then branch it out internally (assuming your tweeter is still going in the door). I'm gonna be mounting my tweeters in the a-pillar when I redo my system so I think mounting in the kicks will definitely make that easier... Thanks for that idea!
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    Registered User iMP|2EZiONS's Avatar
    May 2004
    Colorado Springs/Boulder, Colorado
    I actually just installed some new 6.5 speakers in the front. Infinity References I ended up mounting the crossover in the door panel with some 3M Tape. As soon as I placed them they stuck so they're not going anywhere.
    2005 CGM STi
    Jun 2005
    South Dakota
    Active or passive?
    "I drove like my mother in the first stage" Gigi Galli, WRC driver, Mitsubishi.
