Custom Interior moldings?
Results 1 to 6 of 6
This is a discussion on Custom Interior moldings? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Does anyone know how to make your own custom interior moldings.. say to add the silver aluminum look bezel around ...
    Registered User MarylandEcstasy's Avatar
    Dec 2005
    Question Custom Interior moldings?
    Does anyone know how to make your own custom interior moldings.. say to add the silver aluminum look bezel around the shifter like an STi comes with? What kind of material do you use for a job like that? Just curiosity at its best thanks.
    Dec 2005
    NJ
    I'd just buy it from somewhere...trust me it's not worth the frustration. But then again if you're as stubborn as I am you can always go with bondo or fiberglass
    - Gone
    Registered User Fox05's Avatar
    Jun 2005
    Valdosta G.a.
    Dont use bondo for a soild piece. Take a big peice of foam. Sand an cut and shape it. And then layers of fiberglass and resin. Then prime, sand and paint
    |^^^^^^^^^^^^^^| ||_____
    |.........Beer................| ||.....'|";\,___.
    |_...__...______...__..._|_||_|__|__..._|
    Audio Integrations's Avatar
    Dec 2005
    Camas, Wa
    If it's flat I would use aluminum. Just make a template out of wood, then rough cut the aluminum so it's just a little bigger than the template. Like 1/16 of an inch or so (close) double side sticky tape it to the template, and router away! Make sure it's on the template good, double sided sticky tape is your friend so use alot. Spray a little WD-40 when your routering on the bit to help lubricate. Just don't loose any fingers!!!
    "I see us as being in the art business. Art, entertainment and mobile sculpture, which, coincidentally, also happens to provide transportation."--Bob Lutz
    www.audiointegrations.net
    Dec 2005
    NJ
    Quote Originally Posted by Fox05
    You're right, bondo sucks. I worked well to fix the crack on my bumper, and it dries faster then fiberglass.
    I needed a flat piece to take up a slot in the radio hole after I installed my new head unit, so I went to radioshack and picked up a circuit board. Cut it with a rotary tool, and then sanded it to fit the spot. Then I layed a layer of fiberglass ontop of it, sanded, painted, and all done. It worked much easier then going from scratch.
    - Gone
    Dec 2005
    Thanks for the help. Maybe I'll try the bondo and fiberglass technique with the big piece of foam trick. I like that one alot. Thanks again
    Quote Originally Posted by A member from SRTforums.com commenting on the black AMS EVO
    It really doesn't matter. once he hits 20+ psi in what ever gear its gone. even if you(or any car for that matter) get full boost by 3200, he would real you in a pass like you were going back wards that is unless your flux capacitor is working right Marty .
