Thinking of getting the Kenwood DDX7017 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
This is a discussion on Thinking of getting the Kenwood DDX7017 within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Originally Posted by BlueCamel what sound system do you have hooked up to it Found your post on other thread ...
    Registered User BlueCamel's Avatar
    May 2005
    Smithfield,RI
    Quote Originally Posted by BlueCamel
    i just installed my system yesterday. i would recommend you to not install 6x9 get some components you will get better quality (not as laud as a 6x9 tho.).
    i got some kenwood components on front and some eXcelon on the rear dors; my nex step is to get one kicker L7 and and respective amplifiers (and one for the rear and front speakers).
    Registered User orvtech's Avatar
    Nov 2005
    Miami
    yeap thats me .... i still thinking about the 2 Kicker L7s .. they are going to eat my trunk
    May 2005
    Smithfield,RI
    yah they will, but hey gona get mad sound and bass in there
  6. #19
    Nov 2005
    Kenwood 7015 and speaker sizes
    For those of you that installed component speakers, what size speakers and what adjustments were necessary (if any). I have an '05 WRX with the Kenwood 7015 (hooked up to a photo ipod w/ the aux video input), 2 12'' Sony Subs, and the Kenwood KAC-X811D Amp. It's high time I upgrade the front and rear speakers. What would you all suggest? I don't want to have to get into too much custom work in order to make the aftermarket speakers fit.
  7. #20
    Nov 2005
    Kenwood DDX 7017/7015
    When listening to my 7015 for an extended period of time at high volumes I have noticed that as the unit heats up the sound gets more and more distorted. I have never had this happen with an aftermarket HU before. Has anyone else experience this problem? I guess a 4-channel amp to power some new front and back speakers would solve the problem.
  8. #21
    Nov 2005
    Miami
    Quote Originally Posted by ozjonesjr
    the same size that the car has from factory. you wont be able to completly close the dor pannel tho
  9. #22
    Registered User rpfride's Avatar
    Oct 2004
    pa
    trying to help
    -I guess a 4 or 5 channel amp in the 500-700 power range is what you will need to power all. Check out Hifonics, nice relatively inexpensive clean amps.
    -Do some research for door spacers. the 5.25"(?) are ome size but spacers will let you install 6.5 components without problems. But just research what size spacer is needed for the speaker you decide on. Some have large magnets and realy do not work well in the wrx doors. Focals are hard (maybe impossible) to install. the mb Q's were fine. IMO, focal and dynaudio are tops in components. They just give more range than my mb Q's, but add a sub and it evens out.
    -id love to add my ipod to my hu and need to make that a priority. Taking out the cartridge from the music keg, hooking up the hardware to the pc and downloading is easy but im lazy and usualy keep my ipod alot more updated than my music keg. But i find the music keg to have better quality sound.
    - Have you tryed to view pictures thru the Hu from the ipod. I also have the hp-photo ipod 30g and have picturs on it and just thought it would be cool to view a slidshow while listening to music. .
    I'm gonna be mad if it turns out to be TWill in a wig..
    www.xoticmotorsports.com
    www.guysracing.org
  10. #23
    Oct 2004
    pa
    Quote Originally Posted by orvtech
    ^ not true. the door panels close fine.
    www.guysracing.org
  11. #24
    Nov 2005
    Miami
    Quote Originally Posted by rpfride
    the problem isnot gona be solved by spacers. the "grill" that is covering the speackers is bonded to the door pannel.
  12. #25
    Nov 2005
    Using Ipod photo
    Ya I have the A/V cord going into the Aux. in on the back of the HU. It shows the pictures from my iPod just great. It is pretty cool to have the pictures going while music is playing. I am for sure going to get the new video iPod (since the connection is the same I can just use my existing A/V cable) and use it to watch movies and musis videos. It's like it was made for mobile video systems. I can't wait.
    So I am still a bit confused about speaker size. It sounds like if I get spacers then I could get 6.5'' components to work (in the front). But wouldn't I have to make some kind of new grill cover since the ones on the door would hit the speaker and not allow the door cover to be put back into place? Is it worth the hassle or should I just stick to the factory sizes? Is there a huge sound difference?
  13. #26
    Oct 2004
    pa
    Well, i can tell you that my 6.5" do NOT hit the grill and the pannel is just fine. I dont think people cut the factory door panel and i have not experienced anyone who needed to cut the grill to make the speakers fit.
    I HAVE GOT to get the av cable hooked up!! And i will also be getting the video ipod when released. Thanks for the information.
    They should make a HU that can record video. Get a camera connected and start recording via youre HU. DVD or VCD or hard drive would be nice.
    www.guysracing.org
  14. #27
    Nov 2005
    04/05 difference?
    Thanks for the info on your 6.5'' speakers. Is there any difference in the '04 vs. '05 models that you know of as far as the space for the speakers is concerned? Go get that AV cable connected. It takes about 5 min. to unscrew the HU and plug in the cable. I just ran the wire underneath the clutch case and had it pop out at the cupholders. The video ipods are out so there's nothin to hold you back!
