02 WRX Window issues?
Results 1 to 3 of 3
This is a discussion on 02 WRX Window issues? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; My driver side window isnt lining up with the seal, like a 1 inch gap between it and the door. ...
    Apr 2004
    Belleville, IL
    My driver side window isnt lining up with the seal, like a 1 inch gap between it and the door. I am thinking its loose inside somewhere not making it go up and down properly. Anyone elsde have these kind of issues?
    Jan 2005
    Quote Originally Posted by Notyab
    Take the panel off and tighten the motor nuts, 7 or 10mm i think... its a common problem, dont use the window until you at least check that out... i did and spent a lot more time on it if i just popped the panel, tighten the screws and dabbed some loctite
    Registered User Rice Boi's Avatar
    Dec 2001
    WA
    its a common problem. My car had this issue, I took it to the dealership and they fixed it under warranty, If you are still under warranty they will fix it for free. They thought is was a loose bracket on my car but it was actually a poor assembly problem, the bracket was bent on mine, they added a reinforcement plate and it takes less than an hour.
    HKW
