Problem installing 3 gauge pack help!
Results 1 to 7 of 7
This is a discussion on Problem installing 3 gauge pack help! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; My car is currently equipped with OEM single boost gauge with T connector. When I opened up the package (3 ...
    Registered User WRXreX's Avatar
    Mar 2002
    NY
    My car is currently equipped with OEM single boost gauge with T connector. When I opened up the package (3 gauge pack bought used), this is what saw. Do I just connect this black tubing into the existing T connector for the boost gauge? What's the purpose of this golden insert in the photo? Existing boost gauge tubing doesn't have such thing.
    Your help is appreciated!
    Mar 2002
    NY
    Don't I need a 3 way joint (T connector) for boost gauge install similar to single boost gauge?
    Mar 2002
    NY
    Anyone knows why there is this insert?
    sid
    sid is offline
    Registered User sid's Avatar
    Texas
    take it out and look, there should be a pin hole sized hole in that brass thing. hook it up without, if your boost gauge needle is erratic then use the brass adapter.
    Mar 2002
    NY
    what's the safe way to mount wire in the engine bay? I need to run a wire under the engine for the temp sensor.
    sid
    sid is offline
    Texas
    there's really no right way. just try and avoid hot engine parts and moving parts. use copious amounts of zip ties to secure your wires.
    Registered User WRXTwiztid's Avatar
    Mar 2004
    "i live with me wife and tree kids" IL
    what he said ^ worked for me.
    05' WRB STI
    MODS
    Go raibh tú leathuair ar Neamh
    sula bhfuil a fhios ag an diabhal go bhfuil tú marbh
    May you be a half-hour in Heaven before the devil knows that you're dead.
