Results 1 to 2 of 2
This is a discussion on Gauge Pod within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Does anyone know if the autometer 52mm A-pilar gauge pod will fit the Electronic Greddy 52mm gauges or will there ...
    Registered User PolarisSnT's Avatar
    Aug 2002
    Staten Island, NY
    Gauge Pod
    Does anyone know if the autometer 52mm A-pilar gauge pod will fit the Electronic Greddy 52mm gauges or will there be an issue with wiring or aomething?
    Thanks
    Dan
    Dan- 2004 PSM 5spd
    "Days get shorter, nights get longer, snow gets deeper, life gets better."
    Registered User tekan's Avatar
    Jun 2002
    Atlanta, GA
    I fit three 52mm greddy's in the LoTek Inc pod (www.gaugepods.com) with some minor dremeling to open up the holes a bit. I almost prefer this because then I know the holes aren't so big that the gauges may not stay in place. Typically these pillars are open enough that wiring is not an issue. I did, however, have a problem getting the bottom screw (near cluster visor) to get in, kind of a crappy angle to drill.
    EDIT: The gray paint option is a perfect match to the pillar being removed.
