Here's a pic of my gauge setup, just waiting for the oil temp.
This is a discussion on VDO Oil Temp Gauge - Mounting Help within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Right now I'm getting ready to install an VDO oil temp gauge but I've run into a snag and could ...
Right now I'm getting ready to install an VDO oil temp gauge but I've run into a snag and could use some advice. I bought the gauge and a temp sender off summittracing and a pre-drilled oil drain plug off of wrxtra.com.
I bought the temp sender because the description on the site said the gauge came with mounting hardware and accessories but not the sender. It's a threaded sender and it fits the plug perfectly.
I just got the gauge yesterday and it turns out that the gauge, sender, and signal line are all basically one piece. The line is basically welded to the gauge/sender and there doesn't look like a way I can de-couple the current sender without cutting it.
The current sender isn't threaded, but there is a nut behind it that's way too big for the drain plug from wrxtra. The gauge came with a bunch of adapters but it doesn't look like any of them match the drain plug thread so no dice there.
Can I just cut the current sender off and attach the line to the sender that fits the drain plug? From what I can see, the sender line is just copper with a steel mesh around it.
I'm a little worried about cutting the current sender off since it's all one piece right now and I have no idea what the proper method for attaching the line to the threaded sender would be. Help and ideas are appreciated.
Maybe take it to a shop? I need to install my gauges and havent figured out where I'm putting my sender yet, but when i figure it out, I'll re-post. I may just throw up the extra coin and head to a shop.
I may look into adapters and hopefully find some combination that can use the drain plug threads and those of the current sender. I'm not hopeful though. And if I find something it would likely be 3 adapters long. It would be nice if I knew if I could do the cut/re-attach.
Wish I could help, sorry man. Where are all the mega-subie heads for help on this one, sheesh!
Come on guys, help a brother out!Originally Posted by E-Wrex
There are plenty of opinions on which gauges to get I can't believe there's no one who's ran into this issue before.
