Results 1 to 6 of 6
This is a discussion on lotek a-pillar within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Anyone use double sided sticky tape with the lotek a-pillar? Did it work well?...
    Registered User hobbzz's Avatar
    Oct 2002
    Green Bay, WI
    lotek a-pillar
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    didn't do sticky tape, ut instead drilled a hole in the pillar - not a big deal, only like 1/8 inch big, and covered up by the factory pillar if ur worried about resale value
    Silver 911
    WRX's older brother
    Oct 2002
    Green Bay, WI
    No... I'm just worried about slipping and putting the drill bit through to the outside of the car!
    Nov 2001
    lol don't worry that shouldn't happen - you'll feel it when the drill goes through the metal, its pretty thin and easy to drill into
    Silver 911
    WRX's older brother
    Registered User blackshadow's Avatar
    Apr 2002
    Milan, Italy & Arnhem, Netherlands
    Yeah the drilling is not that hard. I only drilled the top hole and it's holding fine. Too much of a hassle to try and get the drill in place for the bottom one.
    autobahn storming scooby
    Nov 2001
    yep - thats all i did too - the pillar holds in place w/ just the 1 in
    Silver 911
    WRX's older brother
