from what i have heard people do is you file or cut at the spot where it makes contact so it wont touch anymore. I am not sure if it is needed or not but if it wasnt needed i dont think people would waste their time modifying it.
Ryan
This is a discussion on Install kartboy short shifter within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i installed the kb ss and i am very happy with it. i need to put the bearins in now ...
i installed the kb ss and i am very happy with it. i need to put the bearins in now but the shifter it great. i have one questions though. when i installed the shifter i rubbed up against the metal plate when i was in first gear. i tried to move it to the left to get some clearance but to no avail. i decided to take the whole thing out and put the bolts in the rubber piece. is this ok or should i try to put the metal piece back?
2005 WRX
UTEC Stage 2 (Catless)
250.02 WHP
249.27 WTQ
Junior Tuned
Ryan
I am not exactly sure what you did. But what you should do is take the metal plate and rotate it 180 degrees, and then bend the random little tabs upwards so it fits. The area that had contact in first is now near reverse.Originally Posted by br3ez
Edit: It will look like this
