Glovebox rattle
Results 1 to 5 of 5
This is a discussion on Glovebox rattle within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I've got an 04 WRX and the glovebox door rattles on bumpy roads. Anybody else have this problem? A fix?...
    Jun 2005
    Alabama
    Glovebox rattle
    Registered User a$$es of fire's Avatar
    Jun 2005
    Or
    use some weather foam in the area that it is vibrating from i had that problem it was near the latch i put two little 2 inch strips (sticky side attached to the door not the frame) on eather side of the latch and wala no more vibrations. hope it works for you!
    " Burton is like sex in the snow, only board shaped and not as cold" - Lizz ----
    Registered User Just Be's Avatar
    Mar 2004
    S. King Co., WA.
    Those little flat padded sticky dots work.
    Duplicolor, "Scratch Fix 2 in 1" Pewter met. #NG GM 490
    is a perfect match touch up paint for the stock (newer style) '05+ gun metal wheels.
    Jun 2005
    Alabama
    Thanks guys! The little sticky tabs worked great.
    Jun 2005
    Or
    no problem glad i could help
