OHMS... Knowledge?
Results 1 to 7 of 7
This is a discussion on OHMS... Knowledge? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Does anyone know anything about OHMS... like if i had a sub which operates at either 2 or 8 ohms ...
    Registered User RyaNT's Avatar
    Sep 2004
    Somers, CT
    OHMS... Knowledge?
    Does anyone know anything about OHMS... like if i had a sub which operates at either 2 or 8 ohms and a amp that operates at 1, 2 and 4 ohms.. does that mean i will be running a 2 ohm setup?
    2004 WRB WRX
    -Turbo guage
    -Short Shifter
    -Premium Package
    -RS-Limited Ricochet 18" Gunmetal w/ Polished Lip
    -TeiN S Techs
    -Turbo XS RFL Exhaust
    -Alpine IVA-D300 MMS
    -Alpine 2005 Type-R's (2 12's)
    -MA Audio 3600 watt digital Amp (Mono)
    "My lugnuts Require more Torque than your Honda Creates"
    Banned 05WRX0704's Avatar
    May 2005
    Defense Language Institute, Monterey, CA
    it depends on how you hook up the sub
    Sep 2004
    Somers, CT
    explain...
    2004 WRB WRX
    -Turbo guage
    -Short Shifter
    -Premium Package
    -TeiN S Techs
    May 2005
    im not much of a car audio geek but depending if you wire the sub at parrallel or seriers, etc...
    Registered User aznburn210's Avatar
    Mar 2005
    Austin,TX
    okay tell me what you have exactly and i'll see what i can do to help you .. if not check out cardomain or sound domainc or whatever and they have some guides on their site that can help you out with setting up your system.. just remmeber the lower the ohm.. the HARDER you will push the subs with the same amount of watts going to it but at the same time your amp will run a LOT HOTTER
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    For the best efficiency you need to match the impedence of your amplifier to your speaker. So for your case you'd wire your sub to be 2 ohms, and set your amp for two ohms because there are no other choices that match up.
    I'm assuming from your question you have a dual voice coil sub with 4 ohms impedence per coil. That means you'd wire the coils in parallel to get 2 ohms (1/(1/4+1/4)) and for that there should be pictorial directions with your sub.
    06 S40 T5 AWD
    Previous: 2004 WRX
    05 CBR600F4i
    Sep 2004
    Somers, CT
    i could run both at 1 ohm.. but i dont want they to be pushed hard.. at 2 ohs.. i can push 1000watts rms to the subs... but yes i bought the dual 4 ohm ones
    2004 WRB WRX
    -Turbo guage
    -Short Shifter
    -Premium Package
    -TeiN S Techs
