Can you get the a pillar pod to match? - Page 2
Results 16 to 30 of 31
This is a discussion on Can you get the a pillar pod to match? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Originally posted by joe_white It was a picture from a wagon. Maybe that was why i would think that it ...
    Registered User CustomS10's Avatar
    Nov 2002
    Western Mass
    i would think that it was the same..maybe he did a sloppy job?? but the pillar fits down in so dont worry
    -Ben-
    Spark it or Park it!
    Registered User blackshadow's Avatar
    Apr 2002
    Milan, Italy & Arnhem, Netherlands
    apparently the a-pillars on the wagons are longer. I think i read it on vivid racing.
    speedracer: how long does it take to install? I have the same boost gauge as you and i was wondering where you hooked the wires for the light into?
    autobahn storming scooby
    Registered wrxinthehouse's Avatar
    Nov 2001
    awdpirates.net
    There is a small plug behind the stereo that you can tap into so your boost gauge lights will dim with all your other interior lights.
  6. #19
    Registered User driggity's Avatar
    Aug 2002
    Renton, WA
    Yup, the wagon is taller so it has longer a-pillars.
    Big pimpin' in a Legacy GT Wagon
    R.I.P. WRX Wagon
  7. #20
    Nov 2002
    Western Mass
    it took me longer to get the wires down by the pillar to the floor than anything else......i had to splice it with another wire for 12v and ground the 12v i attached it to the ignition system because i have a shift light on there too and i grounded it to a piece of metal underneath the dash........if you get under the dash you see a triangle like shape with a hole but no bolt....get a bolt with a nut and crimp the wire and you're good to go
    -Ben-
  8. #21
    Nov 2001
    awdpirates.net
    FWIW, Speedracer's way gives you light whenever the ignition is on. The way I described only gives you light when your headlights or driving lights are on. Makes your bulb last a little longer. If you are getting an EGT gauge, you'll need a ignition driven power source (like Speedracer's) as well as another source for the light. Plus the wires to the probe.
    My setup:
    Autometer Ultralight boost gauge
    Autometer Ultralight EGT gauge
    Autometer A-pillar gauge pod
  9. #22
    Aug 2002
    Do you have a picture of your setup?
  10. #23
    Nov 2001
    awdpirates.net
    I actually don't. I'm still in the stone ages using my 35mm camera and scanning stuff in, but the pics I took of it didn't turn out. Everyone thinks it's stock because it fits good, the lights are green on the gauges, and I painted the A-pillar to match the other one.
  11. #24
    Nov 2002
    Western Mass
    My setup:
    yep mine needs power all the tiem since it's hook up to my shift light also so i need power when the car is on......thats y.....otherwise i would've hooked it up to the light swithc of foglight switch.
    -Ben-
  12. #25
    Registered User pdrpowerofWRX's Avatar
    Aug 2002
    Springfield, OH.
    i grounded my 3 gauges on the hood release latch.... theres already a bolt/screw there, so i used it.
    go to projectwrx.com if you want good instructions, thats what i did....
    hey speedracer, how do you like the shift light?
    '05 CGM Subaru Impreza WRX Mods (sold)
    '02 WRB Subaru Impreza WRX (sold)
  13. #26
    Nov 2002
    Western Mass
    love the light works great
    -Ben-
  14. #27
    Nov 2001
    awdpirates.net
    Same way I did it. Works great.
  15. #28
    Registered User tuca33's Avatar
    Aug 2002
    Brazil
    Speedracer,,what is that yellow plug on your gauge pod???
    and i am in doubt about using A/F or Oil Temp or Oil Pressure gauges??
    The EGT is the only one for sure.
    As i am planning on the 2 gauge pod(does it look better than the 3 gauge pod??)i will use EGT and??
    some people say A/F is more important,,others say oil pressure,,and i was thinking of oil temp too..
    Wich one is the most important one?
    thanks
    Tuca
    PS:wich Gauges match perfectly the dash green lights??
  16. #29
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    I believe the yellow plug is the Autometer shift light...
    I've heard the Greddy and Omori gauges have very close illumination. In fact Omori sells "wrx factory-look" gauges with a black background, yellow needle and green illumination...
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
  17. #30
    Nov 2002
    Western Mass
    correct
    -Ben-
