Results 1 to 10 of 10
This is a discussion on My single boost gauge mounted on the A-Pillar within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I know a lot of people want to mount a single gauge on the A-Pillar, but there are not really ...
    Registered User Blue EJ20 WRX's Avatar
    Dec 2003
    Orange, California
    I know a lot of people want to mount a single gauge on the A-Pillar, but there are not really any pods out there made to fit Imprezas. Basically what I did was, I bought an Autometer mounting cup, and drilled it onto my A-pillar. Then I drilled a hole behind the cup for the vacuum hose and wires to go through. I know it doesn't look as good as the 3 gauge Defi pod in the center, or a 3 gauge pod on the A-pillar, but I like it better like this than on the steering column. If anyone wants me to explain the steps I took to do this, let me know. I know I'm not the first person to do this, but I have never seen a write up on it or anything.
    Oct 2004
    Westchester Cnty, NY
    Looks good. I was thinking of something like that for an EGT when i go stage 2.
    2008 Satin White Pearl WRX Sedan w/ Navi
    2005 San Remo Red WRX Sedan w/ VF34 (traded)
    Pi Kappa Alpha | New England Flat 4
    Banned 05WRX0704's Avatar
    May 2005
    Defense Language Institute, Monterey, CA
    Quote Originally Posted by D0WNxSH1FT
    not bad. hopefully what i told you helped, did you ahve any problems? i guess not, i didnt get any phone calls.
    Dec 2003
    Orange, California
    Quote Originally Posted by 05WRX0704
    Nope, everything went fine. Thanks
    May 2005
    outstanding! proof positive anyone can do their own mods, even those who are self titled "electronicly stupid"
    Moderator smorris's Avatar
    Mar 2002
    Avon, Ohio
    That looks pretty good.
    Here's another option for those interested in a single pod. I got this from Jamie (SubieGal) but I don't know if she carries them anymore. Check subiegal.com to find out.
    Here's the rest of the photos:
    http://www.morrisgarage.com/wrx/pod/
    Steve - Avon, Ohio, USA - Moderator - Fun Drives and North Central States
    The Morris Garage
    2008 Outback 2.5XT Ltd __2002 WRX Wagon __ 1958 MGA Roadster __ 2008 smart Cabrio __ and a few scooters...
    Bugeye Mafia #338
    Registered User dome's Avatar
    Jul 2003
    looks good guys.
    Where did you guys route the hose and wires for the install? Up through the a-pillar? Smorris, did you have to drill through the pillar?
    Mar 2002
    Avon, Ohio
    Quote Originally Posted by dome
    No holes. I had the snap-in vent cover out for the anti-rattle fix, and ran the wires down beside the end of that. It is covered by the rear of the pod so it does not show. I used silicone to hold the meter in the pod and the pod to the pillar/dash.
    Sorry for the hijack here Blue!
    The Morris Garage
    Bugeye Mafia #338
    Dec 2003
    Orange, California
    Thanks for the comments.
    smorris-
    I liked that pod, too. But I didn't really want to spend the $60-70 for it. It looks nice, though.
    dome-
    I drilled two holes into the A-pillar for the cup to mount on, and then I drilled a hole right behind it for the hose and wires to go through. Then I just ran the hose from the firewall grommet -> under the dash -> up through A-pillar. As for the wires, I ran them across the dash -> under the gauge bezel -> and then tapped into the clock wires. I know there probably would have been a closer solution, but I already knew the correct wiring for the clock, so I just used those wires.
    Jul 2003
    Quote Originally Posted by smorris
    Which snap-in vent cover are you talking about? I'm installing a boost gauge this friday with a very similar pod and I'm not sure which piece you're refering to. Thanks.
    Edit: just did a search and found a thread in the DIY section and on scoobymods. Only problem is all the pics in the thread are coming up as red Xs. Damn.
    Oh well, the write-up is pretty clear but if anyone has pics or a link with pics that would be cool.
