Car remote starter
Results 1 to 15 of 26
This is a discussion on Car remote starter within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i want to put a remote starter on my Wrx but not sure what make to put and is it ...
    Registered User BlueCamel's Avatar
    May 2005
    Smithfield,RI
    Car remote starter
    i want to put a remote starter on my Wrx but not sure what make to put and is it possible in the first place to do since the car is manual? any thoughts please
    Registered User Skreekin's Avatar
    May 2005
    Bellingham, WA
    I would imagine that you could have it done. You would have to have the clutch switch kept on somehow (you know you have to press in the clutch before you start the car, there is a switch that is triggered once it is fully depressed--take a look under your dash and press in the pedal, you should see how the pedal moves and what it contacts) and make sure that you always had your car in neutral (I can't imagine that it would be very funny to put your car thru the garage cause you wanted to remote start). Other than that It should be possible. But I could be wrong.
    May 2005
    Smithfield,RI
    thats a really good point, i am sure that will have to do something about the clutsh swiitsh but also when looking around all of the company's including the dealership said that you can not put it on a manual car !!!
    Registered User stretch_wrx's Avatar
    Aug 2004
    Odenton, Maryland
    I have a remote start feature on my car as part of the viper alarm. I'm not sure which wire it is, but I can check this afternoon if the weather is decent (I'll need to take apart the dash).
    Basically, what you have to do is complete the circuit. When you press the clutch, you turn on a light switch. Complete that loop and voila! Also, there should be a little toggle switch so that you can turn on and off your remote start feature so whenever you leave you car in gear, turn off the switch. If you have a turbo timer, that will help you remember as well.
    Hopefully I can post some pics or something later.
    ~jim
    Registered User o2sys's Avatar
    Mar 2004
    NYC
    how about if i have the upgraded security from subaru? can i still add an remote start and still use my wrx remote?
    LiFe Is ToOoOo ShOrT
    May 2005
    Smithfield,RI
    i have the unpgraded system too, that would be really nice if can add a starter too ! well the dealship refused to instal a starter in my car becasue the my subbie is manual !
    Registered User ScoobVee's Avatar
    Mar 2004
    Im sure you wont find many places that will install it. As most shops dint wanna be held accountable for any injury or death b/c you left it in gear.
    - Local Riceist
    Registered User faylix's Avatar
    Sep 2004
    AVI in MA is a pretty crazy shop. They also have the perfect formula for subaru remote start. They found a sensor to determine if the car is in gear or not. Beyond that feature they also wired it so it wouldn't start if the hood was open and it dies if you press the brake, or drop the ebrake.
    All with my Viper alarm system.
    -J
    Couple of mods here and there.
    <--- My other passion.
    Mar 2004
    Quote Originally Posted by faylix
    Not hooking the hood pin up was grounds for termination when I worked for soundtrack, as far as I know there are wires that indicate if gears 1-3 are engaged on the newer Suby's
    - Local Riceist
    May 2005
    Smithfield,RI
    -J
    i live just outside of MA where is that shop located please?
    Sep 2004
    12 Hawthorn street in Newton MA. Phone number is 6179281188. Just tell em Jeff Sent you.
    -J
    May 2005
    Kansas City
    i'll jump in here on this yes you can put a remote system on any car. most places won't because they don't want to take the blame when you put your car though a wall. i used to work for best buy installing audio, alarms, and what not. when it comes to installing on a manual you have to bypass the clutch. if you guys want i can post up direct wire here for you guys even help you guys install them over them internet. for 5 years i did install and i can tell you WRX and the STI are the easiest car i have ever done. i have the compustar on mine. and if anyone is looking for one i get them cheap.
    Registered User bkzshabbaz's Avatar
    Jun 2005
    Rochester/Brooklyn/N.Virginia
    Im in the market for an security system as well (with remote start)...would u consider compustar better than viper? if so, which model would you recommend?
    Canadian Tech Support:
    "ok, type su eh"
    Customer:
    $sua
    bash: sua: command not found
    "Dont worry ma'am, we're college students, we know what we're doing"
    May 2005
    Kansas City
    viper is owned by DEI so it has a lifetime protection as long as its installed by an qualifed person. but i have had the 4.5 martix, the new viper, and compustar. and i love the features of the compustar.
    May 2005
    Kansas City
    Quote Originally Posted by bkzshabbaz
    the 2WSS-AS (alarm with remote start) is nice but has the smallest of all screens but has the longest range. the downfalls to it you get one remote, no windsheild paging light, no 2nd car mode. and of course the small screen. as for the 2W900FM-AS (alarm with remote start) is the best of all worlds. large screen, 2nd car mode, windsheild paging, good range the same as the viper, and two remotes (one is two-way and the other is one-way). If you decide to go with a compustar i get them cheap.
