If all else fails.. pop the clear plastic and slap some black elec tape![]()
This is a discussion on How to remove ABS Light? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I just finished removing my Brake light fromt the instrument cluster. I took out the cluster and pulled the bulb. ...
I just finished removing my Brake light fromt the instrument cluster. I took out the cluster and pulled the bulb. The reason I did this was because I pulled my ABS fuse and it was always staying on along with my ABS light. Upon inspecting the cluster, it seems that the ABS bulb is somewhere else and not easily accessible. Can someone please tell me how I get to the bulb? Also I could not get the green connectors off of the cluster to pull it out and inspect it.
Thanks
Dan- 2004 PSM 5spd
"Days get shorter, nights get longer, snow gets deeper, life gets better."
why did you pull the ABS?
Originally Posted by Blarg
i pull my fuse in the winter. don't remember the "brake" light coming on though... usually that's a light for the e-brake but my mind is groggy so i can't recall.
07 WRX TR | 03 mazda6
man a whole mess of nachos sounds good right now
***Hawk-Eye Alliance #95*** Kachow!!
I pulled the ABS fuse becasue it almost killed me in the winter when it went off for no reason and almost sent me through an intersection. No i was not speeding, I was goign under 5 mph and i couldnt stop the car. Plus it is annoying as heck when you are braking lightly and hit a bump and it goes ballistic.
As for the tape, I thought of that but I dont think I wil do that. I had the cluster apart and the ABS bulb is under the motherboard thing so I dont think i can pull it.
The e-brake light and the ABS light come on when the fuse is pulled.
Dan- 2004 PSM 5spd
because if you know how to drive it's absolutely useless and actually causes more danger than good.Originally Posted by blarg
I also pull that stupid fuse if i see any snow on the ground![]()
I don't know if the ABS is one of them, but when I had my cluster open I noticed along the bottom, several of the lights had LEDs soldered on to the PCB instead of just bulbs, so you might be out of luck.
Do you have anything to back this up? Not trying to hassle you, but disabling ABS just seems like a bad idea.Originally Posted by rallymaniac
ABS is there for a reason--if your wheels stop moving before your car does, then you're skidding, and if you're skidding, your tires aren't stopping you effectively. Remember high school physics? Coefficient of friction decreases when the two surfaces are sliding.
When the ABS detects that a wheel has locked, it lets up on the pressure quickly to the point just before the wheel would lock. This makes sure the part of the tire that's touching the ground never slides, and gets the best traction it can.
that's true, but subaru's normal abs system is very overzealous, and when you combine it with the terrible re-92 tires they give us and some snow, you can find yourself sliding helplessly into intersections quite often - even when you apply brakes from 10mph with just the weight of your shoe lol it can set it off. basically it sends itsself into "ice mode" easily, which means that it prevents you from modulating pressure while it goes through few cylces of releasing brake pressure and applying it, taking i suppose 3 seconds per cycle.Originally Posted by Chris Biagini
i slid into intersections 4 times at the beginning of winter, definitely driving slowly before applying the brakes (meaning 10-15mph) . pulled the fuse and no trouble since (replaced it when the snow melted)
Go figure. Can't argue with first-hand experience!Originally Posted by yo vanilla
i wanted to add that i'm not suggesting for anyone to tamper with their brake systems - that's just my experience with this car. i'm not the only one though! also every time it happened, it was a very slow speed, very light brake pedal effort. keep in mind that in poor conditions i drive extra cautious anyway, awd or not, so it would be slow speed/light effort anyway... but it was like the abs set itsself off before the tires even had the slightest chance to grip - it was that sudden
i do believe that the tires are much to blame; i'll have different tires for winter next... winter and i'm going to do some carefull experimentation to see how things change.![]()
ABS is not there to help you stop quicker, it helps you not to lock the wheels. I had same situations when i couldn't stop on just a touch of snow when you could even block the wheels and stop faster. Pulled the fuse and have no problems now, and i can stop waaaaay faster than with ABS without even locking the wheels.Originally Posted by Chris Biagini
