Results 1 to 13 of 13
This is a discussion on Help Please!! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I just got a Defi Boost D-Gauge(mechanical) and everything works great except I have no idea where to connect the ...
    Registered User 05silverWRX's Avatar
    Feb 2005
    Nashville, TN
    Help Please!!
    I just got a Defi Boost D-Gauge(mechanical) and everything works great except I have no idea where to connect the white and black wire for lighting. I have an 05 wrx so the console is completely different then the rest of the years...any help would be greatly appreciated. I am a noob when it comes to electric stuff so speak in lamens terms if you don't mind ...thanks in advance
    2013 WRX SWP
    Banned 05WRX0704's Avatar
    May 2005
    Defense Language Institute, Monterey, CA
    do you have an aftermarket deck? if not surely someone here has wiring schematics for this car...the black you could technically bolt to a metal portion of the frame and probably find a 12v at your fuse box...but really, depending where you have the gauge mounted, i found tapping behind the console for all my gauges worked the best.
    Feb 2005
    Nashville, TN
    There are like 30 wires bundled together behing the console, which one?? There aren't any labels, just colors....
    2013 WRX SWP
    May 2005
    i suppose worst case you might be able to tap the cig lighter power wire and ground the ground the way i said or use the ground from the cig lighter.
    otherwise im still searching for a wiring schematic for the stock headunit.
    Feb 2005
    Nashville, TN
    I appreciate your help, maybe I will just fasten a flashlight that points at the gauge so i can see it at night
    2013 WRX SWP
    May 2005
    why not tap to the cig lighter? also, another easy solution (i dunno i havent taken the car apart yet really) might be the power and ground going to that clock in the center dash. i dont see there being much more than 1 or 2 wires to there so i dont see how that could be difficult either.
    Feb 2005
    Nashville, TN
    Yeah everyone says that should be the easiest place but I am having trouble finding those wires...
    2013 WRX SWP
    May 2005
    this should help you...its the radio pin out..its based on you looking at the harness with the wires running into the dash
    1 Violet Radio Illumination Light +
    2 Red/Yellow Right Front Door Tweeter/Speaker (+) (Brown/White at speaker)
    3 Brown/White Left Front Door Tweeter/Speaker (+) (Red/Yellow at speaker)
    4 Blue/Yellow Right Rear Door Speaker (+) (Blue/Yellow at speaker)
    5 White/Red Left Rear Door Speaker (+) (Blue/Yellow at speaker)
    6 Blue/Red Main Fuse Box, Fuse No. 2 (15A) (BATTERY - Continuous Power)
    7 Orange/White Radio Illumination Light (-)
    8 White/Black Right Front Door Tweeter/Speaker (-) (Green at speaker)
    9 Green Left Front Door Tweeter/Speaker (-) (White/Black at speaker)
    10 Yellow/Green Fuse & Relay Box, Fuse No. 9 (15A) (ACC - Switched Power)
    11 Black Chassis Ground
    12 Red/White Right Rear Door Speaker (-) (Red/White at speaker)
    13 Red/Black Left Rear Door Speaker (-) (Red/White at speaker)
    14 N/A Unused (Remote Turn On)
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    Pwn3d!
    Oh, and I think the clock is the easiest place to tap for the lighting.
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
    Feb 2005
    Nashville, TN
    Thanks a bunch 05WRX0704, you are a life saver...The only matches I could tell for sure were the Violet and the Black, so I hooked it in and it worked...I appreciate it...
    2013 WRX SWP
    May 2005
    any day of the week brother
    Feb 2005
    Nashville, TN
    Yeah so funny story, I guess when you said behind the radio, you meant behind the radio..I was looking behind the fan, temp dials oh well it works anyway minus the dimming...my boost is reading right at 12.5 psi. I am bone stock, isn't it supposed to be 13.5?? I am getting my AP tomorrow so I guess if it goes up to 13.5 then the gauge is just off by 1...
    2013 WRX SWP
    May 2005
    Quote Originally Posted by 05silverWRX
    i dont know enough about thhe wrxs yet, but the mazdaspeed proteges always are different as far as stock boost.
