Omori 45mm Gauge View
Results 1 to 15 of 15
This is a discussion on Omori 45mm Gauge View within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Im thinking about going with the Omori 45mm gauge mounted on the oem gauge pod located on the steering column...I ...
    Mar 2005
    Im thinking about going with the Omori 45mm gauge mounted on the oem gauge pod located on the steering column...I just wanted to know how visible and easy to read the gauge is and if the instrumentation is still in view without the gauge blocking anythin, thanks guys.
    Registered User yo vanilla's Avatar
    Nov 2004
    appleton, wi
    well its going to block something no matter what, most likely the lower readout of your tach. one of these days i'm going to get autometer's cluster bezel which puts one guage per side on the lower edge of the instrument cluster. it's about $75
    07 WRX TR | 03 mazda6
    man a whole mess of nachos sounds good right now
    ***Hawk-Eye Alliance #95*** Kachow!!
    Registered User BrandonWRX's Avatar
    Feb 2003
    Sharon, PA
    Those look great on the car, OEM even.....
    MY MODS
    *GET YOUR CLUBWRX KEYRING*
    http://clubwrx.net/forums/showthread.php?s=&threadid=54791&highlight=keychai n
    Nov 2004
    Twin Cities, MN
    I am also thinking about the omori in the OEM cup. Are there any pictures of this setup floating around??
    Jul 2001
    Plains of Eastern Montana
    I have good view w/ mine- egt left, boost right. The nice thing about Omori is they match your oe gauges- needle color and backlighting, they also read in Imperial ie psi and F
    Registered User wizzman's Avatar
    Mar 2005
    Andover, MA
    Goodluck finding an OEM cup. You cant buy the cup alone, so they are a rare and hot commodity. I just ordered this myself:
    http://www.j-spectuning.com/product_...products_id/99
    (And no I didnt pay the listed price )
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    big sky, did you have the stock boost before doing the omori?
    Mar 2005
    heh, I already got my hookup for the oem gauge cup, although its gonna cost me 105$ shipped just for the pod
    Jul 2001
    Quote Originally Posted by dark_rex
    No I had to source both of them- took awhile. I ended up buying used oe boost gauges- want to say roughly $80 ish each- I then recouped a little more and sold just the gauges for ~ $25 each.
    Thasion (j-spec) has tried to source the Lamco pods for reasonable, but w/ no luck. He was going to try and get some made (similar design) but don't know where he is w/ that endeavor.
    mike
    Registered User IDAFC21's Avatar
    May 2004
    Avondale, AZ
    when the time is right im gonna go w/ a 45mm omori boost gauge. ive already got the stock gauge/pod so i wont need to hunt one down. i like the look and location of the stock gauge. then i'll get 52mm egt and oil pressure omori gauges in a dual pillar pod or somthing. id like a dash pod, but then i'd need a third gauge
    Mar 2005
    IDA if you like the dash pod then I'd put EGT, Oil Pressure, and Oil Temp in there. Thats what I'm going eventually.
    Registered User WRXcelration's Avatar
    Apr 2004
    Allentown PA
    wizzman
    i was lookin at that setup....its nice and clean....could you get any night shots of the gauges lit up?
    05 STI
    Speed Comes At A Price...How Fast Can You Afford To Go?
    Mar 2005
    yes that would be nice, gauges lit up please
    Registered User Cheveyboy's Avatar
    Feb 2003
    Charlotte NC
    Just orderd a 45mm boost for my OE cup, how do you pop that sucker out Big Sky?
    Will #1
    LISC #2
    Jul 2001
    Quote Originally Posted by Cheveyboy
    The gauge is in there firm. The Omori gauge which is a smidge larger will be even firmer. You have to lube the Omori gauge to have a fighting chance (I used a light coat of ATF).
