autometer tach hookup
Results 1 to 12 of 12
This is a discussion on autometer tach hookup within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I'm trying to install an autometer tach in my 05 STi and I don't know where to hookup the wire ...
    May 2005
    I'm trying to install an autometer tach in my 05 STi and I don't know where to hookup the wire that goes to the ignition. I'm used to working on small block chevys so I dont have a clue.
    Jan 2005
    first a question for ya is why? second is that I belive autometer makes a DIS (Distributorless Ignition System) interface box that can run the tach. it might be possible to hook it up some other way but I dont know.
    Registered User STiguy's Avatar
    Jan 2004
    Long Island, New York
    check the wires connected to the clock
    LISC #1
    05 STi - 300whp 331wtq 1/4 - 12.7 @107.4 (SOLD)
    06 Evo IX 370whp 386wtq (Under Construction)
    Registered User zoinks's Avatar
    Dec 2003
    Portland, OR
    I'll take that nice STi cluster you have if you're not going to use it.
    Apr 2003
    You have a tachometer already
    Registered User 20wrx02's Avatar
    Oct 2002
    South East Mass
    to each is to own... there should be 3 wires --
    batt
    gnd
    tach wire
    tap it from your ecu
    Registered User MengHang's Avatar
    Jul 2003
    MI
    I've had my tach since day one. It's wired to my ECU.
    But does not read perfect. Before you plug it into your
    ECU, decide if you really want it. I read fine from 0-3000 RPM, but
    slowly deviates. You can still calibrate it for REDline Light.
    Meng Hang
    Ogura Corporation (US Headquarters) Chesterfield Township, MI
    Network System Administrator, IT Supervisor
    Black WRX 2002, ...with 18G with Stock IC.
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    this is how
    Go to you ecu under the pasengers floor. Remove the protection plate. The ecu has many portals. Got to the second one from the bottom. The green tach. control is in c9, this is in the third row, second one to the left. It is green. Splice it and wire into it and you will be set.
    Registered User lukeskywrx's Avatar
    Apr 2004
    Rolla, MO for school/STL
    will there be pictures of the tach when it is installed?
    and yeah i know it is hard to keep track of the rpm when you have that big red tach in the middle of the cluster with that annoying shift light and buzzer.
    good luck on the install
    luke
    I just don't get this drifting thing, why would I spend money to put a car in the wall for a bunch of stupid 16 year olds with dreams of fast and Furious?
    Grip or Die!
    Blobeye Syndicate #17
    Jul 2003
    MI
    Quote Originally Posted by lukeskywrx
    luke
    You can get a pix of my install at:
    http://www.geocities.com/meejhaam/cars.html
    just scroll down and you will see it. If the webpage is not working, it's because
    I have passed my visitor limit for geocities. Suck to have a limit. I'm looking
    to move my page somewhere else.
    Meng Hang
    Jul 2003
    MI
    Meng Hang
    Apr 2004
    its not too bad i guess, but all cops gotta do is look over and see it to harass you.
    Im just gonna build a LED shiftlight cluster for my UTEC and hide it in the vents in the dash so its descreet.
    luke
    Grip or Die!
