Results 1 to 3 of 3
This is a discussion on 2005 WRX glove box door ? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; My door has a little play on the left side. (the right side is tight) Can this be adjusted? One ...
    May 2005
    My door has a little play on the left side. (the right side is tight) Can this be adjusted? One dealer said no but I don't believe much of what they say.
    Registered User WRXSIG's Avatar
    Jan 2005
    Oklahoma State Univ./ St. Augustine FL
    more than likely no....unless you can find a bolt than pop a washer in there.
    Registered User Just Be's Avatar
    Mar 2004
    S. King Co., WA.
    Quote Originally Posted by scrawshaw
    Mine was a little loose too. All I had to do is put one of those padded dot stickers where the door and the frame meet.
    Duplicolor, "Scratch Fix 2 in 1" Pewter met. #NG GM 490
    is a perfect match touch up paint for the stock (newer style) '05+ gun metal wheels.
