Armor All? - Page 2
View Poll Results: Armor All?
Voters
95. You may not vote on this poll
  • Yes its good
    49 51.58%
  • No, dont use Armor All it sucks
    46 48.42%
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 50
This is a discussion on Armor All? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Damn, I wish I would have posted this before I used it in my car. It actually wasnt armor all ...
    Port Reading NJ
    Damn, I wish I would have posted this before I used it in my car. It actually wasnt armor all it was black magic pro shine protectant no water formula for vinyl, leather, rubber, and plastics. I super coated everything single peace of plastic and leather in the car. Took over an hour. Now Im afraid everything will dry out.
    Since I only did it once should I leave it at that (maybe will only dry out a little) or keep using it to prevent drying? And if I now need to keep using it how often?
    Thanks for the help
    Aug 2003
    Richmond, KY
    I wouldn't worry too much about it. I used El CHeapo Armor ALl for the 8 years I owned my Talon TSi and didn't experience any problems with stuff drying out or cracking over time. And I lived in South GA where 90 degree days happend after a cold front went through!
    I am sure there are better products out there but I dont think this stuff will trash your car. I am going to continue using it until I run out and then switch to something like Meguire's.
    Deerfield Massachusetts
    The glossy Amour All causes your dash to be reflected on the inside of your windshield. Not cool at all.
    2007 urban gray STI. KTR Ecutek Re-Flash
  6. #19
    Registered User Just Be's Avatar
    Mar 2004
    S. King Co., WA.
    Only use it for exterior plastic, wheels and tires (in between tire cleanings).
    It's a bit much for the interior. I use the Armorall cleaner on the interior plastic though.
    Get the wipes, not the spray!
    Duplicolor, "Scratch Fix 2 in 1" Pewter met. #NG GM 490
    is a perfect match touch up paint for the stock (newer style) '05+ gun metal wheels.
  7. #20
    Port Reading NJ
    Quote Originally Posted by Just Be
    Too late, already got the spray and overwhelmingly applied it to the entire interior, even the little plastic caps near the back window. Should I just leave it at that or maybe try to remove it with some alcohol or something else? Or should I keep applying it now to keep it hydrated?
  8. #21
    Mar 2004
    S. King Co., WA.
    Quote Originally Posted by SuperScooby
    Just wipe the excess off with a dry towel. It will look and smell better in about a week.
  9. #22
    Registered User WRX-games's Avatar
    Oct 2003
    Arvada, CO
    Maguire's is what I like to use. I think it smells better too
    James
    "Never criticize a man until you've walked a mile in his shoes. That way, if he doesn't like what you have to say, it'll be OK because you'll be a mile away and you'll have his shoes."
  10. #23
    May 2005
    OC, CA
    I am a new owner to the Subaru world but on all the other cars I have had I have never had a problem using armor all. However, I purchase the refill bottles and distilled water, mix it, and put it into my own spray bottle. Spray it on cloth, then wipe down whatever surfaces. That way I get the surfaces clean but don't get that greasy to the touch feeling or the blinding reflection off the windshield. I eyeball the mix somewhere around 30% armor all and 70% distilled water. Change it up to get the result you desire. You won't notice an immediate difference if you do not use distilled water, however the particulates left behind from non-distilled water (tap, bottled) will show over time.
    Not a bad first post - I'll be around...
  11. #24
    Mar 2002
    Calmer than you are
    i wouldn't use it. first of all, its really shiny, in some cases the sun reflection will blind you. also, the crap evaporates and accumulates on your WINDSHIELD leaving a greasy film (ever wonder where that film comes from?).
    go f*** yourself
  12. #25
    Registered User SubyPsycho's Avatar
    PA
    I haven't seen anything this specific applying to Subarus, but I know Dodge specifically states not to use Amor All on any plastic, vinyl, or rubber surfaces. They claim that the plasitcs already have the oils in them they need to resist cracking and other heat/sun damage. I'm not 100% on this, but I remember a Toyota owner's manual I had saying the same thing. That's my $.02
  13. #26
    Registered User boosted scoob's Avatar
    Aug 2004
    Robins AFB, GA
    Armorall contains alcohol and will dry up the vinyl and plastic causing it to crack over time. Not good to use.
    02 WRX - XS Power header/UP/TBE, XS Power FMIC, MBC@15psi, Ported TD04L, Perrin shortram, Alum Radiator - 13.35@101
    05 Mini Cooper S - Bone stock
    95 Mustang GT conv. (Work In Progress) - BBK LT headers & h-pipe, dumped Flowmasters, Kirban AFPR, BBK subframe braces, 6-point rollcage, FMS springs, 70/30 struts, 50/50 shocks, K&N intake
  14. #27
    Registered User ynotajb's Avatar
    Sep 2004
    mmmm,, tater salad
    Quote Originally Posted by blarg
    very interesting... this explains why i got this film on the window in my Legend and never in the subie.... i love learning new things
    dude one time i tried to put the trailer bully into the coiler, and I got all messed up
  15. #28
    Mar 2004
    S. King Co., WA.
    Quote Originally Posted by boosted scoob
    So what do you use? Does Maguires have alcohol in it?
  16. #29
    Registered User br3ez's Avatar
    Apr 2004
    Bergen County, NJ / NEU, Boston
    +1 i use meguiars nxt on the interior.
    2005 WRX
    UTEC Stage 2 (Catless)
    250.02 WHP
    249.27 WTQ
    Junior Tuned
  17. #30
    Aug 2004
    Robins AFB, GA
    I use Turtle Wax 2001 Super Protectant. It's a neon green bottel that is found at most parts stores.
