Results 1 to 12 of 12
This is a discussion on Defi Gauges within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hi, i just got mine Defi BF gauges (boost, oil pre, and EGT) and i was wondering if there was ...
    H4N
    H4N is offline
    Registered User H4N's Avatar
    Nov 2004
    Worcester, Mass
    Defi Gauges
    Hi, i just got mine Defi BF gauges (boost, oil pre, and EGT) and i was wondering if there was any write up to help me install these gauge? or any suggestions to make this process easy and correctly installed.
    Registered User topend's Avatar
    Nov 2004
    New Britain, CT
    i installed boost and oil pressure.. its pretty easy. i used the instructions and the how-to's on scoobymods. just do some research and you'll be fine.
    New England F4
    Top End Racing
    H4N
    H4N is offline
    Nov 2004
    Worcester, Mass
    what kind of adapter did you use for the oil pressure sensor?
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    I put my defi oil temp sensor in a fitting just below the turbo compressor outlet. Its a plug that uses a hex key to remove. When I ordered my gauges, Dan at godspeed sent me the adapter I needed to install it. This spot should work well for oil pressure too. Or you could get the oil filter sandwich adapter.
    For boost, just T into the line that goes to the BOV, and for EGT either weld a bung to your exhaust manifold, or drill & tap the manifold. Either way you're going to have to take the manifold off the car.
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
    H4N
    H4N is offline
    Nov 2004
    Worcester, Mass
    do you know the size adapter though? thats the only unsure thing right now
    Jan 2003
    Albuquerque, NM
    I couldn't tell ya. I bet if you gave dan @ godspeed a call he could tell you, or even sell you one for cheap.
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    Are you measuring the oil pressure under the intercooler? If so you can get Subaru p/n 11024AA210 which replaces the hex-plug with a 1/8-BSPT tapped plug. Then check your manual to see what you have (if you have imperial gauges it's probably 1/4-NPT so get a 1/8-BSPT to 1/4-NPT adapter).
    06 S40 T5 AWD
    Previous: 2004 WRX
    05 CBR600F4i
    Jan 2003
    Albuquerque, NM
    Quote Originally Posted by 04blkWRX
    That's good to know!
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    That's what I did, it works great and was simple to install. I got mine from Dan @ godspeed.
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
    H4N
    H4N is offline
    Nov 2004
    Worcester, Mass
    thread size is 1/8 PT, so i use the subaru adapter right?
    Jul 2003
    NNJ
    From what I can find with a quick search, PT is the same as BSPT so you should be good to go.
    It makes sense that Defi and Subaru use the same threads so I think it's a safe bet that it will fit.
    06 S40 T5 AWD
    Previous: 2004 WRX
    05 CBR600F4i
    Registered User 05silverWRX's Avatar
    Feb 2005
    Nashville, TN
    I just bought a Defi D-Gauge...I want to mount it on my steering column like the stock one is, where can I buy a mount for that?? Can I buy a stock mount from Subaru?? Any ideas??
    2013 WRX SWP
