Results 1 to 6 of 6
This is a discussion on getting gauge senders into engine bay within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i have my pillar set up and my lines for the gauges sitting under my dash.... i see the one ...
    nj
    i have my pillar set up and my lines for the gauges sitting under my dash.... i see the one grommet by the pedal but when i look for it in the engine bay there is a mess of things in the way. i also see all the grommets by the ic but how do i get to them with out taking out the whole dash? any other ones that are eay to get to from inside the car and bay? thanks also i know where to plug in for boost and oil pressure gauges btu what about my mechanical water temp? thanks again
    Registered User BigBallin's Avatar
    Sep 2004
    omaha ne
    Quote Originally Posted by I3oosted Scooby
    take off you ic and there is one right behind it
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    Here's where the gromet is. Just pull off the TMIC and its right there.
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
    nj
    how do i get to that grommet form inside the car though that is my question
    Sep 2004
    omaha ne
    just pull the grommet off and push some wire through.. then you will see where it is
    Registered User RWU00313's Avatar
    Nov 2004
    Comes out right around the gas pedal.
