Results 1 to 10 of 10
This is a discussion on '05 A/C won't turn on with with auto climate control within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I've been pretty happy with the auto climate control throughout the winter, but as things start to warm up, I'm ...
    Registered User mrgreg's Avatar
    Nov 2004
    Beaverton, OR
    I've been pretty happy with the auto climate control throughout the winter, but as things start to warm up, I'm having trouble. If the inside of the car is warm (say 75) and I have the temp set to 65, it blow at full blast at the coldest NON-A/C temp it can produce, but never really gets any colder. I can turn the A/C on and then things are ok until it gets too cold, and I have to turn it back on.
    Is there a reason in Auto mode it doesn't turn the A/C on and off automatically? Anybody know of a fix for this?
    Thanks!
    Registered User roo21's Avatar
    Mar 2004
    Ohio
    ive noticed this too in mine, say if u put it in auto at 65 it takes a lil while before it starts spewing the cold a/c on you. Maybe the climate control has doesnt let it push out any air warmer than 65? Thats what im beginning to think...i noticed this on with heat too. Pry just not used to climate control
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    I think that's just the way it's designed. I've only seen the AC only come on automatically if I use a defroster/defogger setting.
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
    Registered User br3ez's Avatar
    Apr 2004
    Bergen County, NJ / NEU, Boston
    yea i get the same thing in my car. just have to get used to it i guess.
    2005 WRX
    UTEC Stage 2 (Catless)
    250.02 WHP
    249.27 WTQ
    Junior Tuned
    Registered User 68sprintb's Avatar
    Dec 2005
    Cupertino, CA
    i think you need to turn the A/C to auto mode by holding down the A/C button for about 2 seconds. it should flash and then be setup so when the climate control is in the "AUTO" mode it will activate the A/C. the problem i find with this setup is that the AUTO almost always wants the A/C to be on.
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / Scooby Sport New Age centre pipe & backbox
    zab
    zab is offline
    Sep 2004
    if you want to reverse the auto a/c feature, do you hold the button for two seconds again, until it flashes?
    Dec 2005
    Cupertino, CA
    yeah, just hold it down again till it flashes. this also works to turn on/off the AUTO control for the RECIRC.
    Sep 2005
    Central NJ
    Quote Originally Posted by 68sprintb
    for teh auto recirc, is it on or off from teh factory?
    Dec 2005
    Cupertino, CA
    i think they're both auto off from the factory, just my guess though
    Registered User dcpatters's Avatar
    Sep 2004
    Irvine, CA
    I have noticed though in auto mode, when the temperture is reached, lets say 70, the recirculation mode will disable. I guess this is to ensure the set temperature can be maintained. I prefer recir mode anyway. The air cools faster. Without recir engaged, the inside air is cooled entering the cockpit. Besides, ever get caught behind a diesel car or truck without the recirc on?
    2008 Evo X GSR. Custom tuned, Works panel filter, Intercooler pipe upgrade, TBE.
