What guages to get?
Results 1 to 14 of 14
This is a discussion on What guages to get? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I plan on getting an Cobb Stage 2 accessecu. I also plan on getting a turbo back exhaust. I was ...
    Registered User WrxRick's Avatar
    Houston
    What guages to get?
    I plan on getting an Cobb Stage 2 accessecu. I also plan on getting a turbo back exhaust. I was wondering what guages, besides boost, yall think I should get so I can make sure everything is running right?
    I was thinking Voltmeter and boost for sure
    Also, where can I get the 3 gauge box at the top of a center console without the gauges for the subaru? Thanks.
    Apr 2004
    Southeastern PA
    Two of the three you mention can be had here:
    http://www.subaruwrxparts.com/04wrx-interior.html
    Many here like an EGT gauge as well.
    Registered User MasiveMunkey's Avatar
    Jan 2003
    Downey, CA
    I would get boost, egt, and oil pressure.
    -Eric
    Originally posted by lanevoell
    stand up for yourself, painter!
    Wesome +1
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    Don't bother with the voltmeter. Get things that tell you the health of the engine. Boost and EGT are a must. 3rd is up to you, fuel pressure, oil temp, oil pressure are all good.
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
    Houston
    is egt the exhaust temp? whats the egt?...
    And will i need a vacuum pump? Im not sure what thats for...
    Apr 2004
    Southeastern PA
    Exhaust gas temperature.
    Houston
    why would that matter?
    and whats the vacuum gauge tell you? and is it important...
    Apr 2004
    Southeastern PA
    Quote Originally Posted by WrxRick
    I have a relatively conservative (Cobb stage 2) tune and do fine without an EGT gauge. If you have a custom tune and are pushing some of the tuning parameters on the high side an EGT gauge is must to tell if all is OK.
    I do not have a definitive answer to the vacuum gauge question. I should know this better …
    I do know there are devices on your engine that use engine vacuum to operate. The gauge lets you know all is within range for all to work correctly.
    Houston
    I think im gonna end up going with the three gauge assembly consisting of Vac/Oil Temp/Volts. Too bad im gonna have to get rid of the clock
    Since these come from subaruwrxparts.com do yall think the guages will match the stock tachs (mph and rpms) ?
    That would be nice....
    Registered User Kevlar's Avatar
    Dec 2004
    Tampa, FL
    First of all, if you want to get the stock "performance gauge pack", you would get the one with the boost gauge, not vacuum. Vacuum is for N/A cars.
    Personally, I think you would be better off with aftermarket parts. Voltage is rather pointless, and most people feel that oil pressure is better than oil temp, as it is a better indication of the engine's health, and will alert you to a problem more quickly. EGT is a good idea too, to monitor the health of the engine. If your EGTs climb too high, you're risking serious damage to the engine, so it's always a good idea to watch. Personally, I like the combination of Boost/EGT/Oil Pressure, in either the OEM gauge pack, or something like the Defi triple gauge dash pod (http://www.gruppe-s.com/Subaru/subint/defi_hood.jpg). It's more expensive, but I think it looks much nicer. Also, for what those OEM gauges cost, you could have some much nicer gauges (or you could have similar gauges for less).
    Houston
    alright, I cant seem to find cheap exhaust temp guages in price. Anybody have a recommended website to buy gauges?
    Registered User j69raw's Avatar
    Sep 2003
    Lawrenceville, GA USA
    [QUOTE=WrxRick]I think im gonna end up going with the three gauge assembly consisting of Vac/Oil Temp/Volts. Too bad im gonna have to get rid of the clock
    You can put a clock in one of the three ports!, like I did! I hated the fact of loosing my clock too!
    Jan 2003
    Albuquerque, NM
    [QUOTE=j69raw]
    Get a watch, cry baby! jk.
    Registered User wizzman's Avatar
    Mar 2005
    Andover, MA
    [QUOTE=j69raw]
    Yeah but you will be everywhere early with your new Mach V Speed Racer.
