Results 1 to 3 of 3
This is a discussion on CEL burnout within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have had a cel for about 1k miles on and off but i would clear it after a while. ...
    Registered User DjChopstix's Avatar
    May 2004
    Broomfield
    CEL burnout
    I have had a cel for about 1k miles on and off but i would clear it after a while. But recently i kept the cel on for 1.5k and didn't clear it. It just turned off one day and I pulled the code and it was still there. Did my light burn out or is it suppose to do that? BTW it is the code for cat efficiency below normal.
    04 JBP WRX sedan
    -it gets me from A to B
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    The light is an LED, so I doubt it burned out. When you pulled the code, was it a "Pending" code, or the real deal?
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
    Quote Originally Posted by DjChopstix
    Every time you turn the key to "ON" the dash lights will all do a self-check so you will easily be able to tell if it's your light that has failed. Does the light still come on then?
    What modification and/or problem caused the light to come on to begin with?
