adding amp to stock head unit
Results 1 to 4 of 4
This is a discussion on adding amp to stock head unit within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; want to keep the stock head unit and add one or maybe even two amps to the car for speakers ...
    nj
    want to keep the stock head unit and add one or maybe even two amps to the car for speakers and a small box. had a indash 7" dvd player and all that, but im not taking the chance of my car getting broken into again ( my old car) how do i go about adding amps to the stock system? thanks
    Registered User aznburn210's Avatar
    Mar 2005
    Austin,TX
    you will need a harness to add the amp to it as i believe im not quite too sure. will find out later
    Jan 2005
    NW - Beaverton OR
    you can get a hi low inverter and tap spice some wires.. they are pretty cheap around 20-30$ at frys electronics
    Jun 2004
    stock head unit to amps
    What you need is called a line out converter.it allows for rca outputs. any audio store should have it in stock you will most likely need one for each amp. you will ned to wire it into your speaker lines.
