Results 1 to 7 of 7
This is a discussion on iPod mini- mounting option within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I wrote this up for somebody, thought I'd share it here too: It's pretty self explanitory, but here's a quick ...
    Registered User Jennifer Lopez's Avatar
    Dec 2004
    It's pretty self explanitory, but here's a quick tutorial if you want the pod visible instead of simply putting it in the glovebox...uses the belt clip *thing* that comes with mini iPods.
    It's connected with an aiNet cable that plugs into changer-ready Alpine HU's. Sounds great, but it's an AUX input and not controllable from the HU.
    Here's what you need, and where to drill the holes:
    Here's how you do it:
    The only tricky part is removing the pin from the belt clip. Once that's out, you can easily drill and bolt the clip piece to the HVAC vent assembly. The pin pushes back in really easily. I used a piece of double stick foam tape to keep it from spinning, and a hard rubber washer on each side of the bolt.
    All done. I just ran the RCA/mini cable through the heat vent:
    And a bling-blangin' night shot:
    FYI: The HVAC vent assembly is ~$70 from subaruparts.com. So if you're worried about drilling through it... don't.
    Registered User VSGTS14's Avatar
    Apr 2004
    Milford, NJ
    very sweet, i would prob just lay mine somewhere
    FP Green STi
    Mar 2002
    Tokyo, Japan
    I put mine where the ashtray/AC plug is. But I have a regular sized iPod.
    Any issues with it being there when its being blasted by heat/air conditioning do you think?
    Ive been looking for a good place to mount my iPod but I cant find one.
    "I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
    Dec 2004
    No issues with heat yet, hasn't been cold enough since I installed it. But I wear contacts and I'm a sissy little girl, so I can't stand to have the air blast my face. It's usually on the floor vents only, so... works for me!
    I am jealous of the bigger badder full sized iPod's. Size does matter.
    Registered User WRXSIG's Avatar
    Jan 2005
    Oklahoma State Univ./ St. Augustine FL
    ive got a pretty sweet set up for my 20gig. ill take some pics of it tommorow..where can i host pics or whatever...imagestation doesnt really work here
    Dec 2004
    You can post them directly here, go to "manage attachments" at the bottom. Cool to see different set-ups...
    Registered User Redline927's Avatar
    Jun 2004
    New Jersey
    i mounted my ipod mini using the belt clip too, only i velcro (sp?) it in the same spot you scewed it in...so its not permanent, yet solid.
