Wah! overfilled gear oil!
Results 1 to 9 of 9
This is a discussion on Wah! overfilled gear oil! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i took my car to a subaru dealer today to replace stock gear and rear diff. oil with redline 75w-90. ...
    Nov 2004
    Seattle
    i took my car to a subaru dealer today to replace stock gear and rear diff. oil with redline 75w-90. it has 12000mi on it.
    after got home, i check on the gear oil level. Wah! it's at least 1qt overfilled.
    i've heard it's no good to overfill gear oil. but it's a subaru dealer. is that done on purposely, and correctly?
    my wrx is 5speed manual transmission.
    i'll call the dealer tomorrow to find out why.
    ray
    2005 WRX Wagon Crystal Gray Metallic
    Registered User Wrinkleboi's Avatar
    Jan 2002
    Langhorne, PA
    i have also heard that it is not good to overfill. i recently overfilled mine a bit when i did my 30k maintenence. i was able to get under the car and crack the drain bolt enough for it to drip out slowly. its probably only an 1/8th turn difference between a slow drip and having the plug fall out so be careful if you do it yourself.
    bryan
    -2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
    -1994 Black Supra TT 6MT - Pic | Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
    www.TriStateTuners.com
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    You/they can suck it out with a pump.
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Administrator
    May 2003
    With a manual trans, as long as the breather is clear, it won't do damage, just make a large mess when the fluid expands enough to come out the breather.
    Registered User Mr.Mike's Avatar
    Jan 2005
    midcoast maine
    As a mechanic of 6 years I can say this....
    DRAIN SOME OUT
    if you put in too much or use too heavy a weight oil you can blow out seals, breather clear or not. loosen the drain plug and drool a bit out, its a bit messy but... too full is too full and thats all there is to it.
    There are holes in the trany case to allow oil to flow from one area to another, the level must be right for the oil to flow properly.
    mikey
    Administrator
    May 2003
    Quote Originally Posted by Mr.Mike
    DRAIN SOME OUT
    mikey
    In an automatic trans, or a crankcase with pressurized lubrication, you will blow out seals. In a manual gearbox with splash lubrication you won't blow out seals.
    Jan 2005
    midcoast maine
    ok then, leave it over full... not to be a poo poo head but....
    I wouldnt do it, and have drained excess off my self. It maybe ok if you leave it, but personally I wouldnt on my own car or any of my customer's cars.
    mikey
    Administrator
    May 2003
    mikey
    I may have phrased my responses the wrong way. I'm not suggesting leaving it overfull, I'm just stating that it won't do damage, just make a large mess
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    I overfilled mine once too. If you put the 3.7qt that the manual says, then it will be slightly overfilled. Get a funnel and an old oil bottle (with the clear window so you can see how much is in there). Slightly open the drain plug and drain a little out.
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
