Everything you ever wanted to know about WRX light bulbs... - Page 2
Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 87
This is a discussion on Everything you ever wanted to know about WRX light bulbs... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Tan obviously has an engineering background.... I agree completely. I once had a set of 55 watt fog lamps from ...
    Registered User NJSubieTech's Avatar
    Nov 2001
    Hamden, CT/Teaneck, NJ
    I agree completely. I once had a set of 55 watt fog lamps from Hella, into which i wanted to place 100 watt bulbs. I did it, and got the proper fuse for the wattage at 12v. They were INCREDIBLY bright. But what happened? One night while i was aiming them (ie i had them on with no air passing around them to cool them) they caught fire right at the lense....
    "Damn.... this car is wicked fast..." ~ My roomate, owner of a supercharged/intercooled 97 Trans AM
    Mods |
    Registered User Retro's Avatar
    May 2002
    USA, FL
    A friend got some "brighter" lights and they did in deed seem brighter, but he started yelling "speed bump!" and I didn't slow down in time because I couldn't see them. The stupid lights washed out the color soo much that I couldn't see the bump.
    Registered User djrez4's Avatar
    Colorado
    I used to have those blue bulbs in my outback (both the headlights and the fogs). I also had some regular halogen driving lights.
    one night, while driving back from a day of snowboarding at Breckenridge, I got caught in a blizzard. In almost whiteout conditions, the only way I could see ANYTHING was to turn off my headlights and foglights and run with the normal colored driving lights.
    Blue bulbs reflect off of snow 10 times more than regular bulbs (no that's not a scientifically proven fact...I'm just exagerrating) Stick with the normal color and get some yellow fog bulbs.
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
  6. #19
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    i just realized something - tan makes a very comprehensive overview of lighting systems in cars
    mods, can we make this one a sticky?
    Silver 911
    WRX's older brother
  7. #20
    Jul 2001
    San Jose
    Anyone has experience with the Hella 100/80W bulbs? These are Halogen bulbs and Hella is not advertising them as Xenon bulbs. They are supposed to be really bright. I'm upgrading my plug to accept the heat these bigger bulbs put out. The plugs are being sold for ~$3 each.
  8. #21
    Dec 2002
    Ocean County, NJ/Myrtle Beach SC
    I'm going to get the PIAA long range driving lights and mount them under (or maybe over) my liscense plate...They project yellow, in a pencil beam pattern. I have xenon bulbs in my headlights now, and my stock bulbs in my foglights..Is this a good combo? or should i just put the long range lights where my fogs are now, and only have 2 sets of lights? Thanks
    Scott
  9. #22
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    The only problem I can forsee involves the police.
    Any auxilary mounted lights, whether it's driving lights or pencil beam (designed for use with high beams) are still considered to be fog lights.
    I've in the past have ran driving lights with low beams (aim the driving lights down just a bit), without any problems from the boys in blue.
    The problem is, running the stock fogs with the pencil beams...you might get a ticket for too many light operating in the front.
    Likewise you can't run the pencil beams with the high beams.
  10. #23
    Registered User satrya's Avatar
    Apr 2001
    I concur. It's a very good idea to check with your local & state laws. I know in california, you can only have 2 pairs of forward facing lights turned on at any time on public roads. Also, each kind of light (be it auxiliary driving, auxiliary passing, fog, low/high driving, off-road) has certain requirements on their vertical height and cutoff angles. So, you need to make sure the amount of forward facing lights turned on at any given time, total forward facing lights (on or not), beam pattern & cutoff, among other things, to comply to whatever state / local laws you happen to be in.
    Just as an f.y.i., here is a link to someone's experience regarding auxiliary lights. I don't know this person, but it may be useful to read this if you're considering adding lighting units on your vehicle. This is California-law specific btw, but may be useful for other states anyway.
    legality of aux lights
  11. #24
    Dec 2002
    Well im not worried about legality issues.. i'm not supposed to go 120 everywhere but i do :P
    but seriously, i'm just thinking as a lighting pattern..i guess the fogs would be low and out wide, regular lights would get midway and the pencil beams would shoot real far..but will they shoot alot farther then highbeems?
  12. #25
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    I have no experience with pencil beams personally. My guess is yes.
  13. #26
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Yeah, they'll easily outdistance the high beams.
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
  14. #27
    Banned jedimaster's Avatar
    Jun 2002
    What about a brighter replacement for the little bulb next to the headlight- not the turn signal, but I guess you'd call it a running light?
  15. #28
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    the parking light.
    It should be a 168 bulb from the factory.
    194 is more available, but dimmer.
    You could try a "fake-HID" wedge bulb if you want to,.
  16. #29
    Registered User verbal's Avatar
    Oct 2002
    Whats the part number for the rear turn signals? I bought 1156s but the little nubs aren't in the same spots.
    Should I get replacements or would it be alright if I sanded one down?
  17. #30
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    see page 1 of this thread.
    The part number, if I remember correctly, is for a P21W bulb.
