Results 1 to 15 of 23
This is a discussion on Trunk hard to close? Adjust it! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey all... I know I can't be the only one that had a trunk that took a little bit of ...
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Thumbs up Trunk hard to close? Adjust it!
    Hey all... I know I can't be the only one that had a trunk that took a little bit of a slam to get closed...
    I decided to do something about it and adjusted the striker/release assembly (mounted to the body).
    It took a 12mm socket, a ratchet and some trial and error. Must have been 5 minutes total and I'm VERY pleased with the results. The trunk closes without any pressure and pulling the lever inside the car to release the trunk is BUTTAH!
    On my particular car I just loosened the 12mm bolts that hold the trunk striker and release assembly onto the body of the car (in the trunk cavity) and moved it to the TOP (up!) of it's travel. Bolted it back down and voila!
    I know I've heard people complaining about trunk effort before. Why not give this a shot?
    Good luck!
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Registered User F1-racer's Avatar
    Jun 2002
    New Jersey (morris county)
    have the same problem! I havent tried adjusting it yet but, I will this weekend.
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    YUP YUP GOOD ONE!!!!
    -Jim
    Jun 2002
    Honolulu, HI
    Just a note - found out after inspection that if adjusted ALL the way to the top my trunk lid sits a little high on the driver's side.
    I had to drop the striker just a bit (2-3mm at most) and the trunk lid settled down to a more acceptable symmetrical gap and I'm lovin' the ease of use. Give it a shot!
    Aloha, Richard...
    Retired Moderator
    Registered User Retro's Avatar
    May 2002
    USA, FL
    I had the same problem, except mine stoped closing all together. Good thing a friend was watching and laughing at me *****ing at it, and then he walked up with the wrench.
    Registered User DIRSGT's Avatar
    CHARLOTTE, NC
    I have the same problem. I am going to give it a try. I know, releasing the trunk is soo unsmooth.........
    Go fast...
    2002 WRX PLATINUM SILVER
    SHORT THROW SHIFTER
    TURBO GAUGE
    WING
    ALL THE REST IS FILLING.....
    Registered User mesaro's Avatar
    Oct 2002
    MD
    Thumbs up WORKS FOR ME!
    I just tried it.... like u said... BUTTAH BABY! Thanks!
    Jun 2002
    Honolulu, HI
    You're welcome! The hard to shut trunk bothered me for the longest time before I tried the adjustment. Now I'm happy again.
    Aloha, Richard...
    Retired Moderator
    Registered User Natoforces's Avatar
    Jun 2002
    Eugene, OR
    Talking
    Same problem, just ran outside and adjusted mine and it's sweet!
    Thanks!
    Jun 2002
    Honolulu, HI
    You're welcome.
    Aloha, Richard...
    Retired Moderator
    Jun 2002
    Honolulu, HI
    Just wondering if the '03 owners out there are noticing the same mis-adjusted trunks as us '02 owners have had to deal with?
    Aloha, Richard...
    Retired Moderator
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    My '03 is a beeotch to close and open with the lever as well. Maybe they'll fix it next year.
    Jun 2002
    Honolulu, HI
    Hehehe. In the meantime you can always adjust the striker.
    Aloha, Richard...
    Retired Moderator
    Registered User XRW URABUS's Avatar
    Illinois
    Richard,
    I had the same exact problem you were experiencing. I gave the trunk a normal shove and it wouldn't latch closed. I almost had to slam it hard to make it latch.
    This was eliminated when they installed my rear spoiler. I guess the weight of the spoiler gave it the extra oomph it needed to close.
    Jan 2003
    Albuquerque, NM
    Mine had the spoiler on it, and it was still difficult to close. But 2 minutes with my handy-dandy socket wrench, and its all better.
