Replacing the PCV Valve
Results 1 to 11 of 11
This is a discussion on Replacing the PCV Valve within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So i've decided that i'm goin to replace my pcv valve while i'm doing my 30k maintenance. I've searched and ...
    Registered User subieracer18's Avatar
    Oct 2004
    Savannah, GA
    I've searched and haven't really found any help. One person said the pcv valve is under the intercooler. So I have to take the ic off and it should be right below the throttle body... right?
    VF-39 Powered
    298.71HP/282.36TQ on 93Oct
    319.32HP/308.27TQ on 110Oct
    Jul 2004
    OH
    Yup, it should be right around there. From the looks of it in the service manual it's a bit towards the turbo outlet.
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
    Oct 2004
    Savannah, GA
    The link above is for my02 n/a models.
    VF-39 Powered
    Registered User yo vanilla's Avatar
    Nov 2004
    appleton, wi
    this is a pretty cake job, i'll walk you through it.
    -remove bov from intercooler (2 bolts)
    -remove intercooler (1 bolt on either side and a big hose clamp)
    you should now see the pcv valve sticking out of the intake manifold. there's a bunch of hoses in the way. some of these i had to detach, some i could just bend out of the way.
    iirc a 3/4" wrench is what you'll need. it's angled downward so i couldn't get a ratchet on it. also, it was easier to remove standing on the drivers side. be patient.
    replace everything and you're done. wasn't that easy? it was a pain getting the intercooler hoses back on, be careful but push real hard.
    07 WRX TR | 03 mazda6
    man a whole mess of nachos sounds good right now
    ***Hawk-Eye Alliance #95*** Kachow!!
    Oct 2004
    Savannah, GA
    thnx vanilla. I take it you just did your 30k maintenance?
    VF-39 Powered
    May 2004
    I have an 03 wrx. Not sure what year you have, but I've heard the PCV is different for different year models. Anyways, here's my 30K DIY write up w/pics. It's in there somewhere.
    http://www.wrxfanatics.com/index.php?showtopic=18722
    -Jay
    Aug 2002
    SoCal
    Quote Originally Posted by subieracer18
    It is basically the same. The pcv is in the same location.
    Nov 2004
    appleton, wi
    yeah, i did everything, and i'm about to change the spark plugs and trans/diff fluids again (i change those fluids every year regardless, and i used copper plugs last time so i want to switch them out
    Oct 2004
    Savannah, GA
    is it necessary to buy new tranny bolt gaskets?
    VF-39 Powered
    May 2004
    I would. I wouldn't risk it. If you don't get a new one, the old one may leak. They are cheap and you can get them at your local dealer.
    -Jay
