do I need a new alternator?
Results 1 to 13 of 13
This is a discussion on do I need a new alternator? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was parked at the forest preserve finishing my taco bell value meal #7 and I went to start the ...
    WRX
    WRX is offline
    Registered User WRX's Avatar
    Nov 2002
    Montgomery, IL
    I was parked at the forest preserve finishing my taco bell value meal #7 and I went to start the car. Nothing. No clicking noise, no trying to turn over, just nothing. My dash display that shows the mileage even went out. So I waited and the miles came back on so it looked like there was some power. Went to start the car, nothing. So I waited again until the miles came back and then I waited about 5 minutes past that. Then the car started right up! WTF is going on?
    13.12@101mph
    248whp 204lb/ft torque
    mods
    Nov 2004
    Aurora, Il
    Check your grounds on your battery, then check the water level in it. Once you get it running dissconnect the battery. If the car dies, then the alternator is bad, if it continues to run its your battery.
    Administrator
    May 2003
    Quote Originally Posted by big geek
    Some cars need the battery to complete the charging circuit, and won't run with a disconnected battery. Unfortunately, I'm not quite sure which way our cars are wired.
    I don't recommend pulling the mains to the battery while a modern car is running.
    A bad alternator would have complained before failing in a case like yours, so do focus on the battery though as stated.
    Nov 2004
    Aurora, Il
    Last car I did that on was a 89 camaro. I didn't know about the wiring thing, I'll try pulling the cabels on mine after work, let you know what happens
    WRX
    WRX is offline
    Nov 2002
    Montgomery, IL
    it's definitely not the battery, I just bought it when I had my turbo installed a few weeks back. The battery connections are solid too.
    So in that case, I guess it's the alternator?
    13.12@101mph
    mods
    Registered User iMP|2EZiONS's Avatar
    May 2004
    Colorado Springs/Boulder, Colorado
    I gotta get a new one too. For the past couple of days my car's been making a weird winding/screeching sound. It almost sounds like a supercharger after I start up and idle. It doesn't matter if its cold or not. It goes away after a little while. But I can still hear it a little. I think the bearings are worn out or something. Anyone know how much new alternators cost?
    2005 CGM STi
    Registered User Mr.Mike's Avatar
    Jan 2005
    midcoast maine
    Save your self the trouble.... take it to mech. Snap-On makes a wonderful tool that checks batter, altinator and starter draw. It also looks for shorts and bad grounds and takes about 5 or 10 min to run the test. I dont see it costing much, and getting a proper answer the first time makes more sence then guessing your way through.
    Mike just my 2 pennys
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Quote Originally Posted by WRX
    DEFINITELY not the battery? That's a big statement considering you have total symptoms of a bad battery. It's completely dead, then it comes back with a bit of rest and the car not running? That's a battery sympttom. I would guess you were listening to the stereo while you ate your taco with the car off? There is such a thing as a defective battery.
    Take the car to your local parts store and they'll test the battery and charging system for free.
    Quote Originally Posted by iMP|2EZiONS
    Belts?
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    WRX
    WRX is offline
    Nov 2002
    Montgomery, IL
    Quote Originally Posted by GV27
    well I wouldn't have thought it was the battery. I'll go get them both checked out just to be sure I guess. No need to get all hostile about it.
    13.12@101mph
    mods
    Registered User burntclutch4u's Avatar
    Mar 2002
    portland,or
    Yes there is.
    -2k2 WRX Wagoneer, silver
    Jun 2002
    Didn't mean to seem hostile, but it's always a mistake to ignore the most obvious causes. The (limited) info you've given points directly to the battery. Yes, perhaps the battery isn't getting a full charge from the alternator, then is running out of juice faster than it should. But if it seems to be getting a charge otherwise - it has a good charge right after shut-off, doesn't falter on the road, etc. then most likely it's not the alternator.
    My buddy who owns my old CRX recently had an alternator problem. The car would stumble on the road, often not start right after being shut off, etc. He'd just put in an alternator a couple months before, so "it's definitely not the alternator". So he put a new battery in against my advice, decided it was bad and bought yet another (he's got "issues"). Turns out he got a bad alternator from Checker. They gave him a new one free.
    C
    1993 Honda CBR600F2
    Administrator
    May 2003
    C
    You would be surprised at the return rate of reman alternators. When I used to schlep auto parts, I'd say a good 20% would be defective. Most of the companies are subbing the work to some no name inner city rebuilder that "fixes" them, and throws on a coat of paint. Very few companies are actually going through the whole unit.
