'03 wrx stock battery reading low on fluids
Results 1 to 7 of 7
This is a discussion on '03 wrx stock battery reading low on fluids within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was checking out my battery today and I found that the fluid level is at the low line on ...
    Registered User prspect06's Avatar
    Feb 2003
    Land of the Kings
    I was checking out my battery today and I found that the fluid level is at the low line on the battery. I also noticed that when I took the battery out, there was a little fluid on the plastic tray that holds the battery. Any suggestions?
    Registered User ShotgunTC88's Avatar
    Nov 2002
    Ky
    Take some Baking Soda and sprinkle it on the top of the battery and down where it was moist on the tray.......
    If it bubbles the battery is leaking somehow (Should not be though unless it overcharged and pushed the acid through the vent's)
    Check your warranty if it is, And even if it isnt covered I would take it to a shop to make SURE it isn't overflowing/leaking, Acid eat's metal
    .02
    Shotgun
    "Speed Kills......But so do Strokes,...Sign your donar card"
    Registered User 2point5ohyes's Avatar
    Oct 2004
    williamsville, ny
    Quote Originally Posted by prspect06
    your battery is a liquid cell?? thats so weird. i didnt think taht cars were still getting those. huh. i learned something i guess.
    2000 2.5RS I <3 JDM IH8M
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by 2point5ohyes
    your car doesn't have a liquid cell battery? I thought that was standard for all SOA cars.
    Clean everything up ASAP and check all the battery cells. Replenish as needed. Next try to figure out whether your voltage is being regulated correctly. Overcharging is one reason why the battery would steam out fluid.
    BE CAREFUL and if in doubt, don't do this: Take a voltmeter set to measure DC and check battery voltage across the terminals with the car off, take a reading. Is it 12ish? That's normal. Now, turn the motor on and repeat. Is it above 15ish? That could be an issue with your voltage regulator. Are your lights really bright lately? That's another symptom.
    Or, it's just a pesky battery and everything else is OK, you'll have to look and see.
    Feb 2003
    Land of the Kings
    autozone can do all the necessary testing, right?
    I know they'll test your battery but don't know if they'll test your charging system.
