Motor oil level problem...
Results 1 to 3 of 3
This is a discussion on Motor oil level problem... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I barely changed oil 3 weeks ago and now my motor oil is reading low on the dipstick. How is ...
    Jul 2004
    Los Angeles
    I barely changed oil 3 weeks ago and now my motor oil is reading low on the dipstick. How is this when I put 5 quarts the last time I changed oil? 1 more weird thing is that the dipstick is showing different oil levels on each side. Have guys encountered this kind of problem or is thsi normal?
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    Yeah this is pretty typical annoying behavior for oil levels. It's just a weird system. All depends on when you measure the oil and how the stars are aligned or something. Your car probably isn't burning oil, but to make sure you can do another oil change and measure how much comes out.
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
    Registered User spacemanspiff's Avatar
    Apr 2003
    Austin it is
    It's not uncommon for turbo cars in general and our ej20's to consume some oil. Also, I think it's important to let the engine sit for a good fifteen or twenty minutes after it's been running before you check oil level, and make sure the car is on level ground. I find slight variations of the ground level can create inaccurate oil readings.
    A lot of power is good, more is better, and too much is perfect. I mean, if less is more, think how much more more is...
