where to jackup the car from rear and front?
Results 1 to 7 of 7
This is a discussion on where to jackup the car from rear and front? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i want to use a jack stand and work under my car, but i can't find where to jackup the ...
    Nov 2004
    Seattle
    i want to use a jack stand and work under my car, but i can't find where to jackup the car from rear and front. i can't do the side because there's no room to transfer the jack stand from the jack.
    anyone knows? and have a pic to show me?
    thanks,
    ray
    2005 WRX Wagon Crystal Gray Metallic
    cnk
    cnk is offline
    NJ
    The answer is in your owner's manual. Front jack plate behind the oil pan for the front and the rear diff for the rear. Use a block of wood between the car and the jack.
    Calvin
    Nov 2004
    Seattle
    i checked the manual. but it only tells me how to jack it up on the sides which is no use for my case.
    i searched at the net and someone said "crossmember", but i can't find that thing under my car.
    anyways, i managed to use my spare tire to do one wheel at a time.
    ray
    Quote Originally Posted by cnk
    Calvin
  5. #4
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    front plate is ~6in or so behind the oil pan and the rear diff is well . . uh the rear diff. Make sure you have a decent jack, none of those 14' lift things those scare the hell out of me.
    Also if you're going to be under it, jackstands then lay your tires sideways under the edges of hte car as another safety measure.
  6. #5
    Moderator
    Jul 2003
    Maryland
    I will not use a peice of wood to jack/hold anything up again. I saw a car with this method and guess what......3200 lbs on old wood ment it split it like an axe. And of course when the wood split it shifted weight and the jack stand fell. Lucky no one was under it and the car was fine.....just something to think about next time you grab that peice of wood.
  7. #6
    cnk
    cnk is offline
    NJ
    The point is to not use a piece of wood old and thick enough to splinter like that. I usually just use a piece of plywood and it's been fine. The service manuals even recommend using some wood to cushion between the jack and car. You shouldn't have to use something like a 2"x4". . .that would be too big and open you up to for the potential of accidents like the one you mentioned.
    Calvin
  8. #7
            MainFrame's Avatar
    Austin, TX
    Why can't you use the sides? I just jack it up as far as it will go, then slide the jack stand in behind where the jack is and let the car down on it. Never had a problem doing it this way.
