Car Starting Issues
Results 1 to 9 of 9
This is a discussion on Car Starting Issues within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've noticed it a couple of times... I have an '04 wagon with 11,000 miles on it Twice the car ...
    Registered User BarbieJeep's Avatar
    Jun 2004
    Chandler, AZ
    Car Starting Issues
    Twice the car has taken twice to three times the amount of cranks to start. Not sure if it's me over reacting or if it could be anything. Haven't really noticed a correlation between the two incidents so not sure what it could be...
    I also have noticed a whining sound when the car is warmning up. But of course it doesn't happen all the time.
    Any help or guidance woudl be helpful.
    2004 WRB Wagon R.I.P. (Officially a lemon)
    SAVE DARFUR! http://www.savedarfur.org/content
    NEVER let fear hold you back from something beautiful.
    Registered User 04aspenwrx's Avatar
    Dec 2004
    Westchetser County, NY
    yeah my car does the same ****, I have an 04 sedan, its weird, cant figure out what it is.
    ***2004 PSM STi***
    Registered User Richie03's Avatar
    Feb 2003
    PA
    I have had a few occurances with the same problem and I have found that letting the fuel system prime in the on position for about 8 seconds before turning over the engine helps.
    Registered User bthomas6674's Avatar
    Jul 2004
    Brighton, Michigan
    Quote Originally Posted by Richie03
    Funny, I have had the same thing happen with my 05. But I thought maby it was because I was letting it sit for a while with ignition on. Then I would start it. I have a diesel truck so this is just a habit in the cold, for glow plug warm up. Hmmmm ?
    Jun 2004
    Chandler, AZ
    I will have to consistently try the prime thing... thanks for the input..
    what about the whistle while it's warming up.. it's not a belt squeek but a whistle?
    Registered User elohdaeh78's Avatar
    Apr 2002
    Long Valley, NJ
    Its normal my 05 wrx does it also.
    2005 WRX (Short throw shifter, lightweight pulley,STI Splitters,Tein H-Tech springs,Up/Down Pipe, ERZ Catback, Cobb Stage 2, ASA JH8 with Yokohama ES 100s) 13.680@100.46mph
    Administrator
    May 2003
    Quote Originally Posted by BarbieJeep
    I believe the whistle is the IAC valve regulating the fast idle.
    Sep 2003
    Methuen, MA
    from what i have read on nasioc we have weak batteries and this is especially noticeable when the temps are below freezing. when the car has been sitting for a while i prime the fuel pump like mentioned above and it seems to help.
    Registered User spacemanspiff's Avatar
    Apr 2003
    Austin it is
    Does it happen when the engine is hot, cold or either?
    A lot of power is good, more is better, and too much is perfect. I mean, if less is more, think how much more more is...
