question on fuel economy
Results 1 to 15 of 22
This is a discussion on question on fuel economy within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i hope this is the right place, mods move this if it is not thanks. i have an 02 wrx ...
    May 2003
    Buffalo/ Rockland County
    i hope this is the right place, mods move this if it is not thanks. i have an 02 wrx wagon, 4eat, running cobb stage 2, with gt spec exhaust manifold and up-pipe, hacked air box, K and N air filter, grounding mod, perrin pulley, a/c belt removed, and some other crap. ever since i started to mod the car i have been getting a consistant 200 miles to a tank, thats right 12.5 miles to the gallon (SUV milage there wooooo), i am wondering what is wrong, i went to subaru they replaced my fuel rails stating that that was the problem, still have the same problem and subaru has no clue. i was wondering if anyone here had any ideas or things i may try to fix this problem. any help is appriciated
    alf
    Mar 2002
    Tokyo, Japan
    How is the car running? Any decrease in performance? 200 miles to the tank is pretty low...I get around 260 or so.
    "I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
    May 2003
    car is runing awesome. i have no problems with performance, but the thing is i know when i run constant boost im going to get low mileage, but when i babying it, shifting at 2500-3000 rpm and still getting 200 to a tank there is a problem, anyone with ideas
    alf
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    Check your tire pressure.
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
    Registered User tarbaj's Avatar
    Jul 2004
    Livonia, MI
    Do you have a boost guage? Are you pushing boost while cruising somehow?
    May 2003
    tire pressure is right, and no boost when there isn't supposed to be, checked it with the AP this friggen sucks
    alf
    Dec 2004
    Fl
    I have the same problem as you. I have a 4eat with Cobb accessport stage 2, Hks uppipe/downpipes, grounding kit, protorque converter, and I only get like 220 miles on a full tank. I am going to check my tire pressure and maybe replace spark plugs (should I get one step colder?).
    May 2003
    im at about 30k and i wouldn't think it to be necessary to change the plugs already, i was told that they are good to at least 60k, unless im wrong which if i am, time to rip out the plugs. anyone have any insight on this. im glad, well not glad, that im not the only one with this problem
    alf
    1x2
    1x2 is offline
    Apr 2003
    izhazissuez,
    Have you checked for intake air leaks? If none, then, another possibility:
    If a grounding kit is like a lower front spoiler, bigger rear wing, body cladding, etc. I'd look at that, then live with it. Decreasing the air pressure under the body to get the body to sit lower on the suspension and realize extra stick on the road takes a tremendous amount of energy; that's coming from increased drag coefficient, using the above mentioned method of generating it. Rear wings, especially, are practically worthless at less than ~130mph. It's not that they don't "work", it's that the value of the downward push on the tail of the car isn't much help at speeds lower than that. And yet, it creates drag all day long, at every speed. Solid, unadjustable wings work within a narrow speed band, the rest of the time, they just create drag and lower gas mileage. I'd never put a wing on my car, and I've driven several different makes at sustained speeds of ~ 110mph with excellent road grip.
    If it's not, this was a waste of time....
    1x2
    May 2003
    huh? i don't get it, i have been hit in the head a lot being a firefighter so maybe im a little slow, but im not getting the grounding kit causing piss poor gas mileage. the air intake has no leaks what so ever, subaru checked it and said that it was flowing properally. try and explain this to me a little better, but even so wouldn't other people with grounding kits notice the same issues with fuel economy? maybe i missed your point entirely which is possible.
    alf
    1x2
    1x2 is offline
    Apr 2003
    uh, sorry, when my eyes saw grounding my brain read "ground effects".
    May 2003
    phew!, i was going to be very concerned if it was my grounding wires. guess i just gotta deal with piss poor mileage
    alf
    1x2
    1x2 is offline
    Apr 2003
    No, you shouldn't. I'm not a Cobb turbo king, but something's causing your engine to run really rich... otherwise, where' s the gas "going"? Have you called them?
    LOL, ya, pull all the extra wires out of your car, that way it'll weigh less and you'll get better mileage- I'm even sorrier that you had to spend any time "wondering" what the he** I was talking about.
    1x2
    May 2003
    thats the thing, is i had piss poor mileage from the get go. so i don't get what the heck is happening. i got the accessport thinking it would help it, but it hasn't. maybe the intercooler hoses are loose or something, i gotta look again. friggen car! thanks for the response, something is better than nothing i suppose
    alf
    Jun 2003
    Clermont/UCF, FL
    someone said in a thread in engine performance that his mpg doubled when he got rid of his leaky tmic
    23 mpg on a cobb 2.5 vf34 map for me
    271whp/240wtq
    MODS
    mauromotorsports
