need heat....sort of
Results 1 to 5 of 5
This is a discussion on need heat....sort of within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; here is the situation : i have heat when the car is at higher rps i.e. above 3k rpm when ...
    Registered User racerWRX's Avatar
    Jun 2002
    steeltown
    when the car is at idle the temp of the air goes almost as cold as the outside air.
    after awhile of driving the temp of air is ok at idle( what i have the temp dial set to) sometimes ......
    i have been monitoring this for about 2 weeks and there seems to be no pattern or situation that seems consistant.
    any ideas / suggestions ???
    puzzled....
    mike
    have you ever been 4 bagged ???
    Did you just get the 30K service? Your radiator may need burping. Also, did you just install something in the dash? The other option is a switch fault.
    Les jeux sont faits.
    Registered User vtjim's Avatar
    Mar 2003
    Colchester, Vermont
    Quote Originally Posted by SD_GR
    Definitely sounds like air in the system to me. Classic symptoms.
  5. #4
    Jun 2002
    steeltown
    no nothing in the last 2 months (wrenching)
    so how do you burp the system ??
  6. #5
    Jun 2002
    steeltown
    ahh nevermind ...just did a SEARCH and all i have to do is fill up the rad and run it then check it again right??
