torquing factory wheels...lbs?
Results 1 to 12 of 12
This is a discussion on torquing factory wheels...lbs? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've tried searching but can't find it...i know i've seen it before Can someone tell me how many foot/lbs to ...
    Registered User SWRX's Avatar
    Jan 2004
    SoCal
    Can someone tell me how many foot/lbs to torque down on the factory rims? Thanks
    Registered User vtjim's Avatar
    Mar 2003
    Colchester, Vermont
    Owner's manual!
    72 is what my 2002 takes.
    02 WRX Sedan, Silver ("Bugeye")
    TXS Up-pipe, Turbo-back w/cat, Cobb AccessECU Stage 2.
    97 Legacy Outback, White
    Stock. Very stock.
    Jan 2004
    SoCal
    Quote Originally Posted by vtjim
    Owner's manual!
    and yes...a friendly peep always comes to save the day...thanks!....I forgot about that owner's manual thing...
    Registered User fsmwrx's Avatar
    Nov 2003
    Tigard, OR
    Definitely make sure you don't overtorque them, because Subaru is notorious for warping rotors if the wheels aren't properly torqued.
    03' PSM WRX sedan - 326 awhp/303 tq
    Jan 2004
    SoCal
    Quote Originally Posted by fsmwrx
    luckily i got one of those professional torque wrenches from PepBoys for about $30!!...1/2lb adjustments
    Apr 2004
    Southeastern PA
    Owner's manual!
    My 2004 owner's manual says 58 - 72 ft lbs. (page 9-12). Pretty wide range, eh? I use 72.
    Oh, don't forget to re-torque after 50-100 miles.
    Oct 2004
    SFV, SoCal
    Quote Originally Posted by SWRX
    thats good gift idea . .what brand was it? $30 is pretty good.
    Registered User rallymaniac's Avatar
    Nov 2003
    Special Stage
    that's interesting, my rotors start to vibrate a bit when i brake and i was sure that they're begining to overheat and will need replacement soon
    Straights are for fast cars...
    Turns are for fast drivers...
    Colin McRae
    My PHOTOGRAPHY
    Nov 2003
    Tigard, OR
    It could be caused by heat as well, if your hard on the brakes. Overtorqueing and unevenly torqueing your wheels will do it as well. If they are thick enough you can just have them turned to get rid of that warpage causing your vibration when you brake.
    Oct 2004
    Colorado Springs
    On my 93 impreza, constant over torquing led to broken lug studs. For the past 5 years I have used a torque wrench and even when it is in a shop I ask to be torqued properly, but the prior strain on them still led to broken lug stud. 4 out of 5 lug nuts will make your subaru look like helter skelter.
    //max
    Jan 2004
    SoCal
    are the numbers for factory Subaru wheels only or are they for after-market wheels too?
    Oct 2004
    Colorado Springs
    pretty sure it's the same. due to the possibility of warped rotors issue. I have had aftermarket rims on my cars for about 7 years now, and have always used the same. It never hurts to just check them after about 100 miles or so tho.
    ...max
