which air filter
Results 1 to 11 of 11
This is a discussion on which air filter within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok. its time to change my air filter. which one do you guys recommend using for best performance. the stock ...
    Jul 2003
    NH
    which air filter
    ok. its time to change my air filter. which one do you guys recommend using for best performance. the stock wrx filter, the STi filter or the K@N? also whats the difference between the STi and stock filter?
    2004 WRX WRBlue 4EAT (my wifes car)
    You've not specified what "performance" means so I'll answer using my definition WRT an air filter: best filtration.
    I use the stock WRX filter in a stock airbox as the maker intended. My oil analysis data have been very good, proving the filter works very well. I don't recommend aftermarket filters. I've not tried the WRX STi filter though, sorry.
    Jul 2003
    NH
    by performance i meant, will the turbo spool up quicker, will i get better mpg, stuff like that, i know it wouldn't be much of a difference anyways if there was, i was just wondering about it.
    I seem to recall a thread just last week about this, and I'd participated in it actually. Some people do see differences in MPG apparently (from that thread) though others do not. Given that, and given warranty requirements, I'm sticking with a factory filter.
    Registered User rallymaniac's Avatar
    Nov 2003
    Special Stage
    doesn't STi have exactly same filter as WRX?
    Straights are for fast cars...
    Turns are for fast drivers...
    Colin McRae
    My PHOTOGRAPHY
    Rockville, Md and work in Chantilly, VA
    K&N is great
    I've used them in various cars and my motorcycle and they are convenient. It seems to create a smoother transition in the power surge at 3500. Car is easier to drive, I think.
    Commuterrex
    02 Wagon 5 speed
    Registered User bluerex47's Avatar
    Jun 2004
    ohio/texas
    I doubt you gain any real power performance out of K&N although some say you will. All you are doing with a freer flowing filter is letting in more contaminents. It shouldn't really hurt the engine, but it is letting in more junk. With that said, I'll run either Fram or SOA stock depending on if I'm at the dealer to buy another stock filter.
    - chris
    04 wrx, 04 corvette, 66 GTO
    ACT installed at 36k...new Gears at 44k...
    May 2004
    I have a Perrin Panel filter and notice no increase in performance when installing it. I do like the fact that I can clean it and reuse it for some time though.
    The way a filter can increase power is by causing less restriction in the intake tract. In our cars under 300hp the stock filter is adequate for pulling enough air. It is when you go over this amount that you need to replace it with a filter that is more free flowing in order to get more air into the engine. As we all know the more air in the engine the more power, to an extent.
    The STI comes with the same filter as the WRX, but there is a replacement STI filter that is greay and says STI on it that is suppoed to be slightly more free flowing, but is not reuseable. I believe it sells for close to $60.
    Registered User fatgroundhog's Avatar
    Nov 2003
    Ok, from the tests that Hot Rod and Car Craft have run over the years, K&N (et al) will filter and flow almost the same as a paper filter. The difference comes when you compare them when equally dirty. The paper filter loses its flow much more quickly than the oiled filters, so you will lose HP and mpg. If you drive in a dusty area, or don't like changing your filter (I dunno), then the K&N type is best. If you don't mind keeping up with changing your filter, paper works fine.
    Clean paper = clean oiled
    Dirty paper < dirty oiled
    Registered User nvmywrx's Avatar
    May 2004
    chitown
    Quote Originally Posted by subieworx
    i have the perrin panel filter and never had to clean it yet how do you clean yours?
    Nah, it was Colonel Mustard, using teh shockAr in teh bedroom.
    May 2004
    Quote Originally Posted by nvmywrx
    There is a filter cleaning kit that you can get from Perrin for about $11. They recomend cleaning about every 10K miles.
