From i-club:
Subaru is obviously aware of its weak transmission system on the WRX.Originally posted by Kenneth2000
Last week, I ordered the following parts:
1st, 2nd, 3rd & 4th Gears, Synchros & Baulk Rings, along with a bearing kit & gaskets .... and the Input Shaft (that the clutch sits on)
The reason: First off, my 1st gear synchro hardly seems to work at all, and 4th synrchro has been gradually going for the last 2 months ... grinds each time I put it in fourth .... and I'm looking for a solution that can handle my power a little better
So, because I have replaced the clutch with an aftermarket, and I'm making much more than stock hp, I didn't bother trying to warranty it, and decided that Cryo'ing the stock gears would help me out....
Yesterday, the Subaru Dealer called me and said "You're not going to like this"
Apparently, all of the parts for 2nd, 3rd, part of 4th (the gear), part of 1st (the synchros) & the Input shaft, have all been mysteriously discountinued, and replaced with newer, more expensive parts, which of course, aren't available, no one has stock, and no one has an ETA on them......
The Parts Mgr suggested that Subaru either "Re-designed the system" or "Changed Mfg's" ... I go with #1 ...
So, in essense, it looks like Subaru finally got up off their asses and re designed how the input shaft and some of those gears and synchros work, looks like the MY03's will have the better design, and that is also the reason for not having any stock of the new parts, they're all going into the new cars....
Read about it here:
http://forums.i-club.com/forums/show...hreadid=237077
Someone is even thinking about a class action lawsuit!
http://forums.i-club.com/forums/show...hreadid=237910
LinkBack URL
About LinkBacks
