When bleeding the clutch
Results 1 to 10 of 10
This is a discussion on When bleeding the clutch within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; When bleeding the clutch you pull the pedal back toward you after stepping on it and excreting old fluid, but ...
    Banned JDMSubaru's Avatar
    Aug 2003
    Irvine, CA
    Exclamation When bleeding the clutch
    When bleeding the clutch you pull the pedal back toward you after stepping on it and excreting old fluid, but I want to know more specifically how to handle the pedal as you pull it back:
    -I know that the manual states that clutch pedal operation should be slow, but more specifically when you pull it up it gradually pushes itself up with greater pressure.
    Should you resist the pedal's natural popping back up into place to keep the operation slow like it says or should you not resist it?
    Aug 2003
    Irvine, CA
    vump
    Aug 2003
    Irvine, CA
    answer from somebody please
    Registered User tarbaj's Avatar
    Jul 2004
    Livonia, MI
    Well I really don't know for sure but if it is returning on it's own I'd think you shouldn't have to pull it. You don't have to pull the brake pedal and the clutch is the exact same hydraulic type system. It should probably be let out slowly and not just jump off it again just like the brakes.
    You could always get a vacuum pump and use that to bleed it. Then you won't have tomess with the pedal.
    Sep 2004
    Charles City, IA
    I am not sure I understand your concern. When bleeding the clutch you have to:
    1. Top off the master cylinder with fresh fluid.
    2. Open the bleed valve on the slave cylinder, then push in the clutch.
    3. Close the bleed valve, then pull up the clutch (draws fluid from the master cylinder into the hydraulic system).
    4. Repeat steps 2-3 until the system has been bled...keep an eye on the master cylinder so it doesnt go dry or you will get air into the hydraulic system (thats bad).
    If you are already following these steps maybe the increase in resistance is the fact that you are replacing crappy fluid (maybe some gas bubbles) with nice fresh stuff.
    Hope this makes sense.
    -Bosco
    2004 WRX Sedan
    2004 Yamaha R6
    Registered User Dale_K's Avatar
    Jun 2004
    Maryland
    I don't know the answer but I like the turn of phrase 'excreting the fluid'.
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    You can just let it spring back - that's how the system works anyway. Of course it wouldn't hurt to slow it up either. The up side to controlling it is you create less of a whirlpool effect in the reservoir and if you're on the edge of running out of fluid up there, a slow release could mean the difference between sucking air back in or not. But if the reservoir is nice and full it makes no difference.
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Aug 2003
    Irvine, CA
    ok, how much is a vacuum bleeder...if i buy one will i no longer need to open bleed valves?
    Jun 2002
    Not a lot.
    No, you'll still need to open bleeders. Just not as often.
    1993 Honda CBR600F2
    Oct 2004
    Initially you will have to pull the pedal up until soem of the air is out of the system at that point you can let it return under its own pressure. It really isn't that big of a deal. Vacuum bleeding will make the job alot easier at first, then cycle the clutch a while and finish using the manual method. It's easy.
    Remember: Freedom isn't free.
    Old car: 1999 Porsche 996 C2 coupe
    New Car: 2005 WRX Sti
    Verdict: NO comparison-Sti rules
    Previous race car: Eagle chassis sprint car,410cu in Donovan aluminum smallblock dynoed at 806 hp. car weight. 1375 with the driver. Turn right to go left!!! Sprint car racing-drifting for real!
